Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Have the same problem--my KDL-40S2000 turns on for 5 sec then black screen with the "StandBy"LED blinking 4 times, pause, 4 blinks. Is this the transformer? If so, is it economical to fix or toss?
  • ddenning2 Oct 05, 2010
    Immediately before screen went black first time, heard an "electronic" crack sound; unplugged cord and waiting over 1 minute. Turned it back on and not a normal picture for 5 seconds before screen went black and LED "Stand By" started blinking 4 times, pause, 4-- Does this lead you to the power supply board? If so, what est cost and can I install it?
    Am fairly capable with cars, house but have not tried electronics.
    Thanks, Dan
    Very helpful. Gives me some idea of what to expect from the repair shop and a basis to decide to repair or replace.
  • 10,594 Answers
4 times red standby light blinking shows problem of back light failure for some reason.
Possible cause could be either back light inverter boards are defective or power supply board is not providing proper voltages to that inverter boards to function properly.
Power supply board is available separately but back light inverter boards come along with new lcd panel (screen) and it would be costly fix as lcd panel cost would be more than tv worth.
Let me know your expertise level to provide you further info.
Thanks.
Posted on Oct 05, 2010
  • Shahid Electronics
    Shahid Electronics Oct 05, 2010
    Electronic crack/ spark sound before tv shut off shows that any high voltage transformer mounted on back light board got fried so go for back light board replacement.
    This board replacement requires expertise as its connected with thin CCFLs in lcd panel that are very fragile and any mishandling will break them.
    As I mentioned before, back light boards come along with new lcd panel but there is a way to have them separately, contact local tv repair shops as they might have similar broken lcd panel to ake out these boards.
  • silverrollas Dec 19, 2010
    I have a KDL40S2000 and have had a similar problem. The picture comes up for a few minutes than goes blank and the standby lite blinks 4 times. I purchased a used inverter board and replaced it and cured the problem. Did not replace the lcd panel as it was fine. Replacing the board was not very difficult.
Red flashes 6 times and pause for three secs
Using the remote, open the system menu and reset the tv.
Mar 07, 2015 | Sony Bravia Kdl-55ex500 55 Tv, Series Lcd...
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How to fix my Sony bravia KDL-40S2000 turns on then goes on standby blinks 4 times an want go off until you unplug it plz some one help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 08, 2015 | Sony Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Aug 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
1,215 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
