Question about Maytag Neptune MDG5500AW Gas Dryer
The dryer is spinning but no heat what so ever...help!
  • Maytag Master
  • 3,051 Answers
HELLO THERE
There's no heat If your dryer doesn't heat, check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Oct 05, 2010
The air is cold and dryer is turning
If it's electric, could be timer or heat level selector switch, a relay to heating element, the heating element itself bad or the overheat thermostatic switch has failed. How old is the dryer? A lightly used replacement may be less than the repair technition and parts.
Feb 13, 2015 | Dryers
Dryer is Electric. spins clothes but no heat?
What is the setting on for example towels,check lint trap in back when dryer turns does the back of drum turn red,look through door and watch. If you still don't feel heat its the coil,It should be under warrenty.
Jul 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is spinning, but there is no heat. How do I
The Duet manual referenced below will help you with diagnostics.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Jan 17, 2010 | Whirlpool Dryers
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer spins does not heat up
I CAN GIVE YOU THE ANSWER TO YOUR TROUBLES. THE HEATING ELEMENT IN YOUR DRYER IS GONE. CALL A REPAIRMAN AND SEE HOW MUCH IT WILL COST TO GET YA A NEW HEATING ELEMENT INSTALLED.
RODNEY
May 16, 2009 | Kenmore 64812 Electric Dryer
Won't heat
If it spins - you have a problem with the heating elements (usually they are 2 heating elements).I suggest you call a tech and have the deffective elements replaced
Apr 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer heats but quit spinning
Your belt has come off or has broken. Do you hear the motor running? If so, then the belt is broke or off.
Feb 03, 2009 | Whirlpool LER5636P Electric Dryer
How old is the dryer? The heating element is probably no good.
It's possible to fix it yourself. Make sure it's unplugged before you start. You might want to check a parts store, or online to see what the heating element would cost. when this goes bad, the dryer will still spin, and the heat stops instantly. It's a little tricky taking the panels off, but there's not too much to a dryer. An electric motor that powers a belt to make it spin, the heating element, metal sides, top and bottom. Good Luck! Countrycurt0
Jul 25, 2008 | Whirlpool LER5636P Electric Dryer
Dryer won't spin
you most likely broke the belt do you hear the motor spinning?
May 20, 2008 | Kenmore 64602 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
993 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
