Question about Macromedia Captivate for PC
Removing embedded text boxes - Macromedia Captivate for PC
We use embedding for what?
emĀ·bed
?m?bed/
verb
gerund or present participle: embedding
  1. 1. fix (an object) firmly and deeply in a surrounding mass.
    "he had an operation to remove a nail embedded in his chest"
    synonyms: implant, plant, set, fix, lodge, root, insert, place;More sink, drive, hammer, ram
    "rhinestones are then embedded in the leather trim"
    • implant (an idea or feeling) within something else so it becomes an ingrained or essential characteristic of it."the Victorian values embedded in Tennyson's poetry"
    • Linguisticsplace (a phrase or clause) within another clause or sentence.
    • Computingincorporate (a text or code) within the body of a file or document.
    • design and build (a microprocessor) as an integral part of a system or device.
  • 2. attach (a journalist) to a military unit during a conflict.
  • Oct 20, 2015 | Computers & Internet
    How to remove header
    Probably the easiest way is to remove the header text from the actual "header" section (control X) and that will remove it from all pages. Then create a new text box, add the text (control Y) and place the text box at the top of whichever page(s) you want to see it
    Sep 03, 2014 | Microsoft Word 2010
    Erratic print with canon ip 4300 printer
    The document should be formatted as a table with text inserted rather that a group of text boxes.
    Nov 24, 2013 | Canon Office Equipment & Supplies
    Turn on shuts off blue screen B8000028
    The steps to resolve this issue on a product that you want to set up with a wireless connection and on a product that you want to set up with a wired, or Ethernet, connection differ slightly. Depending on the connection type you want to set up, select one of the following methods, and then follow the steps provided to resolve the issue.Method one: Resolve the error on a product that uses a wireless connectionStep one: Print a network configuration page
    1. Disconnect the power cord from the back of the product.
    2. Remove the phone or Internet cable that is connected to the back of the wireless router. Do not reconnect this cable until instructed to do so.
    3. Reconnect the power cord to the back of the product. If the product does not turn on automatically, press the On button (c00636182.gif ) to turn the product on.
    4. Make sure that the blue Wireless light is on. If the Wireless light is not on, press theWireless button on the front panel of the product to turn wireless on.
    5. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
    6. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
    7. Press the Setup button (c01726396.gif ) on the product control panel, select Network , and then select Wireless Setup Wizard . Follow the instructions in the wizard to complete the configuration.
    8. When the Wireless Setup Wizard is complete, press and hold the Cancel button for several seconds. The network configuration page prints.
    1. Make sure that the computer is connected to the same router that the product is connected to.
    2. On the network configuration page that you printed in 'Step one: Print a network configuration page,' look in the General Information section. Make a note of the following information.
      • IP Address
      • Subnet Mask
      • Default Gateway
      note.pngNOTE:Each of these addresses is in the IP address format. For example, 192.168.1.100 is an IP address. Make sure that you note the numbers and the dots exactly as they appear on the network configuration page.
    3. Open a Web browser, such as Internet Explorer or Mozilla Firefox, on your computer.
    4. Type the product IP address in the address bar of the Web browser, and then pressEnter . The Embedded Web Server (EWS) page for the product opens.
    5. On the EWS page, click the Networking tab.
    6. In the left pane of the Networking screen, select Wireless (802.11) , and then select theIPv4 Configuration tab in the right pane.
    7. Select Manual IP .
    8. In the IP Address text box, type an IP address that is within the range of 192.168.1.10 to 192.168.1.60. For example, the IP address 192.168.1.25 is correct, but 192.168.1.61 is incorrect.
    9. In the Subnet Mask text box, type the Subnet Mask address that you located on the network configuration page.
    10. In the Default Gateway text box, type the Default Gateway address that you located on the network configuration page.
    11. Click Apply to save these settings.note.pngNOTE:After the new IP address is set in the EWS, the computer loses the connection with the product, and the EWS page becomes unresponsive. This is expected behavior. Wait 10 seconds, and then continue with the next step.
    12. Close the Web browser.
    Step three: Restart communication and complete the installation
    1. Press the press and hold the Cancel button for several seconds. The network configuration page prints.
    2. Make sure that the product is connected to the network and that the IP address matches the IP address that you typed in 'Step two: Set the product IP information in the Embedded Web Server (EWS).'
    3. Connect the phone or Internet cable to the back of the router.
    4. Continue the product installation. If the software has already been installed, insert the software CD into the computer CD drive, and then select Add A Device from the menu that appears on the computer.
    If the installation is successful and the error message does not appear again, the issue is resolved, and there is no need to continue troubleshooting.If the installation is not successful and the error message appears on the product control panel, continue with the steps in the Workaround section.Method two: Resolve the error on a product that uses a wired (Ethernet) connectionStep one: Print a network configuration page
    4. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
    5. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
    6. Make sure that the network cable, or LAN cable, is connected to the computer and to the product.
    7. When the product is connected to the network, press and hold the Cancel button for several seconds. The network configuration page prints.
      • IP Address
      • Subnet Mask
      • Default Gateway
    6. In the left pane of the Networking screen, select Wired (802.3) , and then select the IPv4 Configuration tab in the right pane.
    1. Press and hold the Cancel button for several seconds. The network configuration page prints.
    Or else remove CMOS battery located on formatter, wait 15mts refix then check..
    Oct 06, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    Wireless does not seem to work any suggestios
    Go to HP Wireless Printing Center.
    If you need more help come back.Post / thumbs / testimonial are welcome!
    Nov 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    How to edit the text in pf
    You will need to convert the PDF document to editable format. This software can help you do this: http://www.pdftodocconverterpro.com
    Dec 08, 2009 | Avanquest Nitro PDF Professional
    How to erase my music on friendster?
    in friendster, you can click the edit profile then click the customize, then erase the embeded text in yourmedia box the n after that click save to take effect,
    Jun 30, 2009 | iLO (2 GB) MP3 Player
    Color chart in Word 2007 prints as a black box
    have you tried saving the document as a 2007-document, and printing it out after that?
    Feb 07, 2008 | Microsoft Office Professional 2007 Full...
    Ocr
    fonts wont be embedded when converting a document to OCR. You'll have to change fonts & styles manually... sorry but it has to be done this way..
    Dec 06, 2007 | Adobe Photoshop 7.0 for PC
    Macromedia Captivate for PC Logo
    Top Macromedia Computers & Internet Experts
    Tony
    Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
