Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
When i start my computer a problem occurs that searching for boot record de-o..ok and then hangs
Earlier it a sohwing tat invalid boot.ini fie but the system was started.bt ow t is not booting .please give a clear suggestion.
Start ur pc by safe mode and check once...or else when system is booting up press F8 and go for last known good configuration....
Posted on May 28, 2008
  • Microsoft Master
  • 13,433 Answers
Use the windows cd to perform a repair installation if you get startup errors or the system wont start.
Invalid boot.ini when starting PC
The boot file is misplaced in your PC. to solve the problem boot it from an OS installation disk. then when you get the phase of installing there will be an option called "repair your computer". click on it and follow the instructions..(takes under 5 minutes) also use startup check to remove common errors..i can give you an accurate description if you post the correct OS i can give more accurate steps.
Apr 05, 2014 | Microsoft XP Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Invalid boot file ini fix dell opti plex 270
bonvicin66,
Unfortunately, you are going to need to have a Windows Disk to run a Repair Install from the disk. If running a repair install does not resolve the boot.ini error you will need to format and reinstall Windows.
To get a Windows disk you can search the internet for a disk. If you are in the US you can try getting a disk from the link below.
Dell Backup Media Online Request Form
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell OptiPlex GX270 PC Desktop
Cannot get into safemode; using F8 repeatedly or continously does not work
which OS you are trying?
if it is Windows Xp then the option must working
With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
if not done then try the following method.
Close all open programs
Click Start, Run and type MSCONFIG in the box and click OK
The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
The computer restarts in Safe mode.
Perform the troubleshooting steps for which you are using Safe Mode.>
When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
moz-screenshot-4.pngplease dont forget to vote if found helpful.
Jul 30, 2011 | Computers & Internet
When i start my conputer invalid boot.ini to C:/ducument apear before open.
When you start your computer it says invalid boot.ini and then freezes there? Or, your system is booting into windows; and your receiving another error ?
Sep 02, 2010 | Computers & Internet
Recuperacion de sistema
COMIENCE, FUNCIONE, MSCONFIG, LENGüETA de Boot.ini Las 2 trayectorias del cargador se deben enumerar allí, y la que doesn' el trabajo de t se enumera como DEFECTO. Destaque la trayectoria funcional del cargador, chasque el SISTEMA COMO botón de DEFECTO, entonces AUTORIZACIóN
in English:
START, RUN, MSCONFIG, Boot.ini TAB The 2 boot paths should be listed there, and the one that doesn't work is listed as DEFAULT. Highlight the functional boot path, Click the SET AS DEFAULT Button, then OK
Jun 25, 2009 | Dell Dimension 8400 PC Desktop
Memory not written error application occurs (OK to TERMINATE)
Try this: I got it from another website
Hit Windows + R and type cmd and press enter afterwards. Navigate to c:\ by typing cd.. until you are there. Boot.ini is hidden and write protected which means that we have to change that before we are able to edit it. Type the following commands:
  1. attrib -r -h -s boot.ini
  2. edit boot.ini
  3. Look for /NoExecute Optin or /NoExecute Optout and change that to /NoExecute AlwaysOff
  4. Save the edited file
  5. type attrib +h +r +s boot.ini
  6. restart the computer
Dec 29, 2008 | Microsoft Windows XP Professional
BOOT.INI deleted. How to re-create this file?
type in run "cmd" then presss enter then type "bootcfg /?" it gives u some help .
Dec 28, 2008 | Microsoft Windows XP Professional for PC
Will not start up
if at all, the case is tat, it just starts ur computer and gets hanged at a stage where, ur motherboard company name is displayed, then,
click del button, and there, in settings, u enable quick boot and restart, and it will work..
pls, let me know , i f it works
Jul 17, 2008 | Computers & Internet
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
