Question about Sony Ericsson Walkman W705 Cell Phone
Phone is not working . it turns on, searches for network then turns of again.. this is repeating continuously.. i cant get it out of mass storage to update is fimware
  • 4,102 Answers
Hi, the problem you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it.
you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you dont have this just ask the phone shop to back it up for you.
their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independant shops instead of one of thos bigger branded ones.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Oct 05, 2010
I cant conect mu lg p500 to internet on my pc
Do the following settings.
1.Connect UBC between phone and computer (Don't turn to mass storage or anything)
2.Launcher->Settings->Wireless & networks->Mobile networks->Data enabled
Check it
3.Launcher->Settings->Wireless & networks->Tathering & portable hotspot->USB tethering
Check it
Now you can start surfing without any PC suite.
Cheers,
Mr.Maduraikaran.
Sep 11, 2011 | LG P500 Cell Phone
I need to on code my nokia n97 to be able to reset to factory settings
The following procedure will delete everything you installed and stored in the internal phone memory. The mass storage and external memory card won't be modified.
  1. Turn off the phone.
  2. Slide the keyboard out.
  3. Press and hold Shift, Space, Backspace, & the Power Button at the same time.
  4. Continue to hold the keys. The phone will turn on, and you will see the white background, then the Nokia logo, continue to hold the keys.
  5. Let go of the keys when the screen no longer changes.
  6. Your phone should go to the Setup stage, where will ask you to choose your country.
  7. If you see the country setup, this means the reset was successful. Else you will need to repeat the procedure.
Mar 22, 2011 | Nokia N97 Cell Phone
Welcome to samsung mobile initializing file systems... wait 30 secs mass storage initalizing... wait (1min) mass storage mounted...
Samsung (and other) smartphones are like a computer, when you turn them on for the first time they require a little amount of time to boot up. This is normal, and necessary for the phone to work properly. If the phone continually says "Mass storage initializing", try turning off the phone and removing the battery for 30 seconds then returning the battery to the phone and rebooting.
Mar 07, 2011 | Samsung Jet S8000 Cell Phone
I used sony ericsson c902i.when connect my phone to computer using usb cable,i choose mass storage mode.when i've be asked on my phone to continue with that action,i choose to continue but my computer seem...
Connect your phone to your computer again and get through the process again. After selecting the Mass Storage. You can go to your computer on the desktop and check if you can see the icon for your phone. If you do see it then go ahead and double click on it. If it opens and shows you the files in it, then it means that the problem is solve.
Kind Regards
Sep 24, 2009 | Sony Ericsson SonyEricsson C902/C902i...
How can i sync my lg spyder 2 to my computer to transfer pictures
you need a micro sd card. when you connect your usb cord to your computer the phone will prompt you with a screen that says USB Connection Modr. Select "USB Mass Storage" and click yes again to continue.
From this point you will search for your drive under "My Computer" and drag and drop files.
Hope this helps!
Aug 30, 2009 | LG enV VX9900 Cellular Phone
N72 phone
hello there!
Find this app:
FontRouter[1].LT.for.v9.Build20071109.unsigned
1) Install in the memory card.
2) Create a folder in memorycard at data en name it fonts (when there is allready one don't bother, there should b a file there called fontrouter ini
3) make fonts (choose a ttf and copy them 3 times so u have 4 fonts.
4) Rename them in2:
nohindisnr60
nohindissb60
nohinditsb60
S60ZDIGI
Now for the hard part...
5) make sure your cell doesn't use the memorycard (otherwise the mass storage won't work)....
Think about the message setting and change it in2 phone memory...
6) Connect with mass storage and rop the 4 files in the e:data/fonts
7) Unplug and reboot...
8) That's it....
When U want 2 change it, that's even harder.
Because the new fonts R being used by the memorycard, the mass storage won't work anymore. U can't delete the without mass storage....
1) Use the app X-plore and search 4 the frontrouter.ini file in the same folder.
2) Edit the file and change the setting on the 12th row:
enable=1
in2 this:
enable=0
3) save it and exit...
4) Reboot (this will restore your normal font)
5) Now use mass storage (again everything exits on the memorycard) and rename the folder fonts (E:data/fonts) in2 font (so loose the s)
6) Delete the files in there
7) Reboot and that's it.
When u want 2 change them at point 5 U have 2 drop the new ones in there after U deleted the old ones.
Then use X-plore again and edit the ini file and change it back 2:
enable=1
reboot and U have new ones....
Good luck.
Feb 14, 2009 | Nokia N72 Cellular Phone
Rokr e6
To New Guyxxx:
For me too similar problem comes rarely, I wl restart the phone and the problem will b rectified automatically. Try this, if u still face the problem You just remove your memory card frm phone and plug it again. Also ensure the memory card is working properly.
To Guest:
You have to use Motorola phone toolkit to copy and backup the contacts and messages. For E6 to be detected as Mass storage, the drivers are preinstalled in XP, so no need of drivers.
Aug 29, 2008 | Motorola Mobility ROKR E6 Smartphone
Sony Ericsson Walkman W705 Cell Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
