Question about Whirlpool LEQ8000JQ Electric Dryer
Element good, no heat - Whirlpool LEQ8000JQ Electric Dryer
    President:
  • 1,218 Answers
Good day,
I assume by what you said that you have accessed the heating element itself and checked it with a meter.
Make sure you have 220 volts to the dryer. The motor will run, even if one side is out since it runs on 120 volts.
There are many items that can cause your problem, but the common ones are in the area of the heating element. They are all either limit safeties or limit thermostats. They should all check out at zero ohms resistance. The most common to fail is a skinny white device located near the center bottom. It looks like this.
It causes 90% of the problems, so check it first. There are others on the back panel, so if that's not it check those as well. They are either round or squarish in shape, including one that many models have attached to one of the terminals of the heating element.
There are other possibilities, such as the heat selector switch, timer ect. but this usually covers 99% of the no heat problems on this machine.
Posted on Oct 05, 2010
We can't get our hot tub to heat. The heater light comes on but the heater still won't heat.
heating elements are resistors that get hot
one end will have 115 volts but the other end should be considerable less because the resistance of the heating element drops the voltage
if you used a ohm meter you should be reading a resistance of 500-1000 ohms for a good heater element but with your readings , there will be no resistance so the element is faulty
Apr 06, 2017 | Element Water Heaters
Dryer won't come on. Wire block burned. Wires test good. Heating coil lookes burned
A good heating element should have continuity. When the heating element breaks, there is no continuity between the heater terminals. But sometimes, the broken ends of the heating element can make contact with the metal heater housing (from vibration) and draw a large current, causing the symptoms you have described.
To confirm a "short" between the heating element and the heater housing, check for continuity between the housing and each heater terminal. (The shorted part of the heating element is usually welded to the housing.) Occasionally, the short will not be welded, but a visual inspection will verify (welding scars and black soot) that a short has occurred, intermittantly.
Replace the terminal block, heater, damaged internal wiring, and possibly the thermal fuse, thermostats, and power cord.
Good luck
Mar 06, 2017 | Dryers
Does the heating element have mercury in them
no
it would be a very weird heating element if you did.
heres a good overview of typical heating element materials
Heating element
Nov 15, 2016 | Dryers
Not heat when washing
replace heating element
Apr 07, 2015 | Whirlpool Dishwashers
Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Feb 07, 2012 | Dryers
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    Kenmore Dryer -will spin but not heat and dry
    The ohms reading on a heating element should never be zero. The resistance is what turns electricity into heat. You may have gotten a bad part. Check it again with NO power to the system. Unplug it or flip the breaker to be sure. You should definately get a reading on a good element. Good luck
    Dec 06, 2009 | Dryers
    No heat
    if it's a gas dryer, it's the thermal fuse. if it's an electric dryer, it's the thermal cut-off located on the heating element housing. good luck bud :)
    Jul 06, 2009 | Dryers
    Heating element continuity?
    Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
    Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
    Mar 11, 2009 | Kenmore 62602 Electric Dryer
    The dryer works but does not heat
    Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
    Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
    Whirlpool LEQ8000JQ Electric Dryer Logo
    79 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
