Question about Dynacraft Girls 16" Barbie Bike
I need a rear brake pad for this bike. Where can I get one?
Target
Posted on Oct 08, 2010
2003 Suzuki VL 1500 Intruder LC REAR DISC RATTLE,HOW DO I REPLACE IT?
Hello Dale, this is an easy job on your bike. Use a flat head screw driver and remove the brake pad cover...it will pop off.
Remove the hairpin type clips off of the ends of the brake pad pins.... Use pliers & pull the brake pad pins out from the front of the rear brake caliper....Clean the rear brake caliper's piston with brake cleaner. Use a rag and wipe it clean...Reinsert the old brake pads into the caliper. Place a pry bar between the brake pads, then push the inner piston into the caliper body, this will allow room to install new pads.... Remove the old brake pads...Coat the brake pad pins and the new brake pads metal back plates with high-temperature grease.
Slip the new brake pads into the rear brake caliper, then push the brake pad pins halfway into the caliper. Slip the spring clips into place between the brake pads and the brake pad pins. Push the brake pad pins completely through the rear brake caliper. Push the hairpin clips back into the brake pad pin tips. Snap the brake pad cover onto the top of the rear brake caliper....
Pump the rear brake pedal until the pedal feels firm, indicating that the brake pads have closed around the brake rotor...No bleeding will be needed because the system was never opened - That's all there is to it...i hope this information is helpful & good luck with your bike.
Nov 22, 2011 | 2003 Suzuki VL 1500 Intruder LC
Brakes need to be tighten
The wound steel cable that connects your brake lever to the brake pads can be adjusted via a screw or nut at the top of the brake pad assembly. Simply loosen the assembly and gently tug the wire end toward the front of the bike tire to tighten brake grip; tug it backward to loosen. Tighten the screw partially to hold the cable in place, test the brakes with the brake lever, and adjust again if necessary before fully tightening. It may help to put the bike on a stand or hold it so that you can spin the wheel, check that the brakes are adjusted so that the pads do not rub the wheel. You can do the same thing with the rear brakes. You will need a small tool to loosen and tighten the brake pad assembly; your household toolbox should have something :)
While you are adjusting the brake tension you should also check the brake pads for signs of wear. If your bicycle brakes squeal, show uneven wear or are perfectly smooth, go to a shop and get a new set! Regular brake maintenance is very important for bike safety.
May 19, 2011 | Cycling
My rear breaks aren't working. bike has been in storage for about 3 years
brake pads are most likely dried up. you need soft rubber for brake pads
Mar 12, 2011 | K2 Zed 24 Boys' FrontSuspension Mountain...
Is it very difficult to replace rear brake pads on a honda vtx 1300r
Personally I have never replaced pads on that particular bike but if it is like most rear disk pads, should not be too bad. I just remove the 2 bolts holding the caliper to the frame. Lift the caliper off enough to slide the pads out. Get a small C-clamp or something so you can gently push the caliper piston back in. Then install the new pads and bolt the caliper back on. Be carefull when pressing the piston back in because is might cause your master cylinder to overflow a bit. Once the pads are on the bike, pump the brake a few times until the pedal gets firm. Should be no need to bleed the system as long as you don't open any brake lines.
Hope this helps!
Aug 26, 2010 | 2005 Honda VTX 1300 R
How do you change rear brake pads on a 2004 fatboy
There are two bolts that hold the rear caliper into the rear caliper bracket. Remove these two bolts and the caliper lifts out of the bracket.
Notice how the pads and the anti-rattle hardware is positioned in the bracket. Replace the pads and hardware making certain that you get the fiber side of the pads against the brake rotor.
Now, you must get the piston back into it's bore. I use either a large C-clamp or a large pair of slip joint pliers to press the piston back into it's bore. Use rags or thin pieces of wood to protect the finish on your caliper.
Once the piston is completely pressed into it's bore, carefully replace the caliper back into the bracket without disturning the pads. Slowly depress and release the rear brake pedal until you get a full firm pedal. Test the brakes before you ride the bike. Failure to properly service the brakes on your bike can result in serious injury or death. Make certain that you do this job correctly or take to an experienced person to have it done. If your bike quits it makes you mad, if it won't stop, it hurts you.
Ride safe.
Steve
Aug 23, 2010 | 2003 Harley Davidson FLSTF Fat boy
What brake pads etc and disks do i need for my bike. ZX6R Ninja (1996) (P).
These are the part numbers from Kawasaki
Front brake pads, you will need 2 sets 43082-1142
The front rotors have been canceled, I will give you the part number 41080-1398-5C
Rear brake pads 43082-1171
The rear rear is also canceled part number 41080-1389-FB
Apr 29, 2010 | 1996 kawasaki ZX-6R Ninja
Just changed the rear tire and need help getting the rear break back on 1999 heritage softtail
If you have the wheel properly installed, putting the rear brake back on the bike should not be a problem. The brake caliper bracket should act as the wheel spacer on the right side of the bike and must be properly positioned in order to get the axle back in.
With the caliper bracket on the bike, make sure the brake pads are properly positioned in the caliper bracket. Double check to see that the pads are not installed backwards, especially on the back side of the rotor. Carefully, slide the caliper down over the pads, without distrurbing them, and into the caliper bracket. If this is giving you a problem, you may have to press the piston in the caliper back into the the caliper just a bit to clear the pads. If you replaced the pads with new pads, press the piston all the way back into the caliper. I usually use a large pair of slip joint pliers or a large C-clamp to do this with. Make sure you put a rag or something around the caliper to protect the paint. Good Luck!
Dec 27, 2009 | 2000 Harley Davidson FLSTC Heritage...
Rear brake pad installation
Hi Marquettepar, for more information about your question please visit the websites below. Good luck and have nice day.
Replace rear brakes pads softail heritage EVO
Apr 12, 2009 | 2000 Harley Davidson FXST Softail Standard
Rear Disc brake is rubbingke
I had the same problem with my Hope mono-mini.
I took it into a shop and the guy showed my ruffly what to do.
On the side that the disk is rubbing you need to put a spacer on the bolt between the brake mount and the bike's mount.
If done correctly (or understood what i meant) it will pull the pad away from the disk a little bit and it will stop rubbing.
Hope it helps
Ed
Feb 01, 2009 | RTO Hope Tech X2 Mtb Mountain Bike Disc...
Dynacraft Girls 16" Barbie Bike Logo
73 people viewed this question
Top Dynacraft Cycling Experts
Tony
shaun taylor
Mike
Are you a Dynacraft Cycling Expert? Answer questions, earn points and help others
