Question about Toshiba Satellite A105 Notebook
Toshiba A105 Upon turn on it starts with the toshiba boot up screen and the inicator that shows the progress of loading goes almost to full range then the screen boots to a j only on the screen with no keyboard controls. Tried running recovery disk and got a 080E890000 partition condition failure
  • 121 Answers
I advise you to reinstall windows on a new partition
Posted on May 28, 2008
    Problem Solver:
  • 15 Answers
Retsrat yr system n run enter into bios setup try disabling all hard ware u know u will not be using for the main time then save changes n restart yr system. if it continues restart it again but this time ppress the f8 key so as to enter startup option now chose save mode then enter to boot it should boot. if don, click on start then on run type msconfig a window will come out then go to startup then disable all click on ok then restart yr system i think it will be ok now.
hope this helps
Toshiba satelite a105 keeps looping in the boot menu
No blue screen or number, it use to work find, this problem start last week
Jul 05, 2017 | Toshiba Satellite A105-S1712 Notebook
My Toshiba A105 only goes to Start Windows Normally Screen
Most likely You have an incompatible program installed. Launch MSCONFIG (Start-Run-msconfig) and disable any suspicious or unnecessary services. Upon completion restart the computer.
Dec 14, 2012 | Toshiba Satellite A105 Notebook
Toshiba A50 Not able to boot from CD
When you load the cd and reboot, when you see the toshiba screen, start tapping F12, see if this brings up the temporary boot menu, if it does choose the cd and watch closely for "press any key". If there is nothing showing, might I suggest you get an external cd drive that attaches by usb. You will then have to get back to the BIOS and set the usb as your first boot device and try to boot again from the usb cd drive. Good luck.
Oct 08, 2009 | Toshiba Sattelite A105-S2071 Notebook
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
My Toshiba laptop screen shows 2 loading boxes then goes black
Perhaps this can help...
I have the solution for the non booting Toshiba that I wrote almost a year ago. This tutorial (written and pics from the repair of my m35) is applicable to laptops that shut down without any warning, laptops that turn on only sometimes, and laptops that simply refuse to turn on (LEDs blink, fan spins up for a second and then everything just goes dead). So if your laptop does not turn on, it goes completely dead within a few minutes after bootup, here's the link to the tutorial. The repair takes about an hour, there's no need of replacing any parts, reinstalling any software or any other thing. The only investment in repairing your laptop with this tutorial is your time. Basically, you can repair your laptop within the hour, without spending any money for any parts or software.
http://imateski.blogspot.com/2008/08/toshiba-satellite-m35x-motherboard.html
Mar 31, 2009 | Toshiba Satellite A105-S4254 Notebook
Display
If you've got exacttly the same each time you're start, then the VGA card has issue, or even the motherboard and CPU.
If not then try to chock the base of the screen with two fingers when starting, if nothing happen try to chock the middle of the keyboard and several spot around it. (it's a little bit brutal but the easiest way to find a bad contact or dead components)
If you feel like open it then this website will help you:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
and for the screen:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
good luck
Dec 16, 2008 | Toshiba Satellite A105 Notebook
I have a Toshiba A105 Laptop, Screen goes blank after windows....
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Ron
Dec 15, 2008 | Toshiba Sattelite A105-S2071 Notebook
Freezing up
I think you need to do a power cycle. remove the battery and use tha AC adapter alone. If it boots, then thats good. U can try also booting on safe mode by pressing F8. Then re start the notebook in normal mode. If it wont works then i think u need to reinstall windows as a last resort. U need to use TOSHIBA RECOVERY DISK this time.
Sep 05, 2008 | Toshiba Satellite A105 Notebook
Toshiba A105-S4254
Probably its the inverter.
May 12, 2008 | Toshiba Satellite A105 Notebook
LCD display problem
My Toshiba Satellite does a similar thing, It goes gray while I am working on it. The only way to continue to work on it is to complete shut it down manually and reboot. I took it to Toshiba they said nothing was wrong.
Oct 19, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
398 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
