Question about Dryers
The dryer sounds like it has a flat tire. like *** *** ***, like its off center or warped or something...
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Posted on Oct 05, 2010
I have a 1989 ford f-250, when i have it going over 40mph it starts shaking like if my tires were about to fly off,any idea what can be my problem
Could be a few things, warped rotors, u-joint, upper control arm. Best thing to do is take it to an alignment shop. They will not align it if something is bad on your chassis or front end until you get it fixed. Good Luck
Aug 05, 2016 | Ford Cars & Trucks
My car shakes when i get to 55mph or higher and shakes when i brake to stop
you have a warped rotor and possibly an imbalanced tire as well..did you ever use "fix a flat"? that will do the same thing as well to fix that? you'll need to bring the tire in to a tire store and empty the remaining fix a flat stuff and the tire leak fixed correctly. if fix a flat was never used it's the first two things I mentioned imbalance in the rim/tire or warped brake rotor
Sep 25, 2012 | 1999 Chrysler 300M
Today I had the front rotors and brakes both sides as well as the right side U-Joint replaced. I'm still experiencing a shimmy/vibration at about 20 MPH down to a stop. What else could be causing this??...
If it does it only when the brakes are applied it's a warped rotor. If it does it without the brakes applied it's a tire. Probably a cord separated in the tire.
Dec 24, 2010 | 2006 Dodge Ram 2500
My lg dryer is making a loud knocking sound when running. Sounds like tub is warped or something. Any suggestions for a fix??
rum rollers,drum glides or belt idler assembly, all these items can be found on eBay. note the routing of the belt, the idler assemblage is next to the motor. this website shows the rollers/glides and how to open the dryer, hope this helped Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Nov 28, 2010 | Dryers
2004 avalanche..46k miles..was making a noise that sounded like something was warped ..abs would engage below 5 mph..took to repair shop and they replaced both front hubs..said the abs was fixed ..sensors...
Try rotating your tires from front to back. It may help with the noise. Get a front-end alignment which can also help with the noise by correcting a "rub" sound that originates from the 2 front tires fighting each other for control.
The place which replaced your bearings is probably correct. When you get bad bearings they do not always fail evenly across the 360 degree turning of the bearing race. If you imagine a donut with a flat spot representing your bearing- as the donut spins with the flat spot cause by a disintegrating roller, the tire is bolted to the donut. The tire is going to hit the pavement differently every rotation because of the play in the bearing is at that same spot.
This play will create small cups in the tire shape at the low spot transmitted by the bearing. When you replaced the bearing , the marks in your tire tread remained. These edges need to be worn off. Or some tire stores can Shave a tire, in an attempt to make it round again.
If you have a normal size spare, you can put the spare on the left front side of your vehicle and see if the noise goes away. If the rims are different on the spare, you can have everything remounted and pay for rebalancing and put the unused spare as a front tire. Then you know the spare is at least good as a spare, but noisy.
Nov 06, 2010 | 2004 Chevrolet Avalanche
Sounds like it has a flat tire
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 09, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Kenmore dryer sounds like flat tire
take the top and front off your dryer and check the front drum slides. The top slide usually wears out.
Nov 17, 2008 | Kenmore 93142 Gas Dryer
The freezer door on our GE side by side fridge does not shut tightly in the center of the door causing a frost and ice build-up on the outside of the door, ( in the inside edges. We have been told that...
There are ways to adjust the hinges, and loosening the screws on the plastic door liner will allow you to "warp" to door a little bit in an effort to get it to line up flat and square to the opening. Sometimes the gasket gets folded up on the hinge side and won't let the door close properly. If you try these adjustments and the door just can't be fitted nicely, you have a serious ploblem. Use something straight to see if the cabinet is warped or if it is the door that is warped.
Jul 23, 2008 | GE Refrigerators
Dryers Logo
198 people viewed this question
Top Dryers Experts
