Question about Iomega Computers & Internet
I plug in my hard drive to the USB port, but the computer/USB port wont detect it. This happens on multiple computers
  • 2 more comments
  • Mark
    Mark Oct 05, 2010
    Does your external hard drive have one or two USB plugs? Specifically, what model is it?
  • henryhan20 Oct 05, 2010
    it has two, but only one usually needs to be plugged in... the main one. The model is LPHD-UP
    XP.
    It is not available in the My Computer section. And I will try again tomorrow when I am back in my office. Thank you for your help. I will let you know the results.
    Problem Solver:
  • 8 Answers
Henryhan20, OK, good. Plug both of them in when using the external hard drive. The USB plugs supply power to the device as well as serve as a means to transfer the data. USB ports can carry 5 volts of power (max). If the hard drive is over 4200 RPMs then it will most likely need more than 5 volts to work properly. Try plugging both USB jacks in concurrently.
Hope this helps,
Mark
Posted on Oct 05, 2010
  • 1 more comment
    I did that and its still not working. The light comes on, and the computer even makes the sound indicating a new device is plugged in, but there is no option of getting into the hard drive. Am I able to recover my files?
  • Mark
    Mark Oct 05, 2010
    If I may, what Operating System are you running?
  • Mark
    Mark Oct 05, 2010
    There are a few things we can try here.... first off, Is it available under My Computer (in your drives section)?
    Next would be to restart the computer and attempt to plug both in again (after the machine is fully loaded.)
    Let me know the results.
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a WD USB External HDD (160 GB), when I connect to my USB port it detects the drive but not displaying in My Computer. Hope there is no issue with USB port. Then why the drive is not detecting,...
Your unit is detecting the electronics on your external case, not the internal hard drive it contains. If that is not being recognized that usually indicates a failure of the hard drive logic board, not a good thing.
Remove the drive from case and plug in directly into your pc. If still not recognized that confirms initial diagnosis. Your usb port is ok but the drive is fubar and since the logic board is toast data recovery will have to be done by the pros and be expensive, very expensive.
Always a good idea to have multiple backups!!!!!!!!!
Sep 20, 2017 | Western Digital Passport 120GB External...
My Lacie was working fine till I brutally unplugged it from usb port when I about to go home from office. After I go home, I plugged it to my home computer, it cannot be detected any more. Next day I...
Please take the Hard disc to a technician for a soldering repair job.
It happens in many cases, that after brutally unplugging the drive the connector connecting the drive to the board of the hard drive gets loose... or the connections break which does not let the hard disc being detected.
A repair job will fix the issue for you for sure.
May 20, 2010 | Computers & Internet
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
I have a constant flashing green light and computer wont detect it
First, try connecting the external drive to another computer. If the second computer fails to detect it, chances are that the housing or, the drive inside have failed. Determining this requires a basic knowledge of external drives. If however the drive is rckognized the the second computer, turn off the first computer and strt it up again (not restart). Then plug your external drive to a usb port directly (not to a hub) and, it should be detected.
Nov 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
103 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
