Question about Garden
Need push rods for riding lawn mower and engine gasket need prices
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor · Operation Manual.Craftsman Lawn Mower manuals - ‎Craftsman 247.370310 - ‎Craftsman 247.37030
Aug 02, 2015 | Craftsman Garden
Pedal is free- mover does not move
Two possibilities to look for.1. The linkage may have lost a connecting pin. Follow active rods from pedal to control arm on transmission. 2. There is a disengage rod to allow the machine to be pushed without the engine running. If this is in the disengaged position the transmission will not drive. Look at the rear and low down for a lever or rod which is connected to the transmission.
Sep 28, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Engine wont start
Replace the damaged push rod and check the valves and compression.
Jul 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John deere 400 20 hp engine with no compression on left cylinder
hi me jim 30 year lawn tractor mechanic., possibly stuck valve 2 blown head gasket (cheep) or bad rings/broken connecting rod (big bucks) will need to rebuild that engine or replace it?? 2 to see if broken rod pull cylinder head off ,to see if piston goes up/down or tap top of piston down ..Light tap.. engine will still run on one cylinder ,that how I got my jd 400 tractor engine had blown a rod!!!!.. pd. $175. what a steel also free engine transplant!!!!!!!
Sep 10, 2012 | Garden
Does a 23 horse kawasaki lawn engine have a timing chain? what would cause a bent push rod
a lot of the over head valve engines run into this carbon build up on the valve stem will bend a push rod
Jul 08, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
24 hp engine. one bent push rod, second rod missing lost some power, no other problems
This happened to me,the engine sat for some time and the valves were varnished with stale fuel,they stuck in the guides.This bent the push rod and it was only running on one cylinder.The missing push rod worked its way into the crankcase through an oil passage . I took the engine sump of and found the push-rod. I cleaned removed the head,cleaned the valves and guides replaced push rods and gasket and it ran fine after that.I use fuel stabilizer now,it keeps the varnish from forming.
Jun 23, 2009 | Briggs & Stratton Garden
My mower was running fine and then quit as if out of gas. It will turn over but will not start
If it quit as if out of gas, it would have coughed, emitted black smoke, and smelled bad. If this is what happened and there is gas in the tank, think dirt in the fuel system which would need to be cleaned and blown out with compressed air.  But if it just quit clean with none of the above symptoms, think failure of the electronic ignition system.
May 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Apr 28, 2009 | Garden
Gasket for briggs and stratton
I recommend  Jack's Small Engine Repair; they have always had the detail part I needed and their prices are among the lowest.
They will probably have an illustrated parts page for your model.
Jack's
Mar 22, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
