Question about GE Spacemaker JVM1640SJ Microwave Oven
Partial venting Our new over the counter GE microwave passes the tissue test, but still some steam by-passes the vent and is ruining the finish on the above cabinet doors. Was told that this is "normal", but surely it can'ty be.
  • GE Master
  • 9,098 Answers
Are you running the vent fan whenever you cook on the stove top? You should.
And you should run it on high if you're having steam problems.
Otherwise, you'll need to do something like use a small counter top fan to help circulate the air better.
Please let us know if we can help further.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 30, 2008
I need the specs for GE Spacemaker XL JVM1339BW002 and need to know since I am replacing this unit w/another GE what type of venting do I need, and will I need to purchase a new trim kit?
The GE Answer Center can answer those questions. 800.626.2000
Give them your full model number.
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for more free help.
Nov 26, 2016 | GE Microwave Ovens
I have a Siemens Microwave Model # HF36V305/01 and the fan will not shut off? Any ideas as to how to fix this problem?
Microwave Automatic Vent Fan Operation - YouTube
? 2:07
https://www.youtube.com/watch?v=6LoK1geGXbQ
Aug 1, 2011 - Uploaded by GE Appliances
This video explains the operation of the automatic vent fan feature on over the ... We have a Hotpoint Counter ...Missing: siemens ‎hf36v305 ‎01
Microwave vent fan won't turn off - Appliance Repair Forum
Nov 26, 2015 | Siemens Microwave Ovens
Ge spacemakerxl microwave jvm1650 vent is not drawing air
It is possible, you have removed and checked the filters, still the intake is low even without the protective filters. The system will need to be taken apart to find the opstruction, or as you said a hole in the venting mechanism.
Jul 04, 2012 | GE JVM1650 1000 Watts Microwave Oven
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Is there a piece I can install on the bottom of my over-the-range microwave that will help keep the front of the microwave from being covered in steam when cooking on my stovetop?
Every over the range microwave has a vent on it that should be venting that steam. I don't know of anything you could put under there that would solve your problem as that is where then vents are and they would be blocked. It sounds to me as though your steam is not being vented properly, and this could also happen if the steam is being vented back into the room instead of outside as many OTR microwaves allow you to do. Its a little bit of work to vent it outside but I myself did that with my microwave and have never had a steam accumulation problem.
May 03, 2010 | Maytag Appliances Over-the-Range Microwave...
My ge microwave is rusting under the turntable.
This is due to either liquid spills or steam buildup or both.
In rare cases, you may have bad air flow (blocked vent or clogged filter) or a weak internal cooling fan or hood vent exhaust fan.
It's recommended to wipe off any moisture that accumulates inside, and leaving the door open a while after cooking may help, too.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels, etc.
You need to clean the area, sand it shiny, then clean it squeaky again.
Then you can get high temperature appliance paint in spray or brush-on form from local appliance part stores or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
You can find helpful exploded view diagrams and order parts (such as charcoal filters, etc.) by entering your full model number from the tag on the oven here.
You shouldn't need to remove the oven from the wall to take care of this problem.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jul 24, 2009 | Sharp R-820B Convection/Microwave Oven
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How does the vent work?
Under cabinet microwaves generally have two configurations for venting.
1) There is a vent cover plate on the top or rear (sometimes both) of the unit that can be removed and connected to a duct that vents up to the roof. If you do not have such a duct installed then that cover plate should be left on the unit so that it vents in configuration 2.
2) With the external venting ports sealed with the cover plate(s) the microwave simple draws air from the bottom (usually through 1 or 2 grease capture screens) and vents it out thought the front/top of the unit. This configuration isn't very useful as it just blows the air back into the kitchen. Many people don't both using the microwaves blower in this configuration.
Feb 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Condensation betwejn the front door glass
This would require disassembly of the door panels, which is not recommended unless really required.
You can download the installation guide to help you troubleshoot and correct your venting issues. That should be priority one.
It may be a clogged filter, a bird's nest in the outlet, etc. etc. Failure to vent can cause control panel and keypad trouble if it continues.
The manual / guide is found here: http://www.geappliances.com/service_and_support/literature/
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
155 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
