Question about Intertherm Heating & Cooling
Intertherm gas furnace model - MGHA-077ABFC-05 Our pilot is lit but the furnace won't kick in. We have used it once already this year and it worked just fine. Any help is much appreciated. We really want to avoid paying for a costly diagnosis and repair. Thank you
3 Suggested Answers
  • 587 Answers
SOURCE: Intertherm MGHA-075BFC-01 gas fired furnace - air
Probably the limit switch is open.
Posted on Oct 16, 2009
koolbreezes
  • 540 Answers
SOURCE: Intertherm furnace pilot won't light
There should be a reset button in the upper chamer next to the fan motor. In the middle ,push in on the center red button to reset it, this tripps because it says I,m not gettig enough air flow due to a plugged or dirty fliter located on the front cover or door.
Posted on Dec 18, 2009
Pilot stays lit but burners dont come on
Burners could be clogged from previous years of use- turn off pilot-then gas and remove and clean burner then replace and follow your steps backwards then start system
Oct 04, 2016 | Intertherm 56000 Btu Gas Furnace
Intertherm wiring diagram for model number MGHA-056ABFC-05
you have a 24 volt shorts check your thermostat wires to see if they are frayed or if they are touching anything. Check your outside wires also go to the thermostat.
Jul 12, 2014 | Intertherm Heating & Cooling
I have a intertherm gas furnace mgha-056abfc-01 the pilot light will not stay light.
If it's not the limit switch, perhaps the thermocouple or gas valve is defective.
Was there a gas outage?
Oct 24, 2012 | Heating & Cooling
Instalition of intertherm model#MGHA-077ABFC-02
Here you go, get back with me if you need anything.
b220604d-b686-4495-96f4-93ea09674f99.pngd8d58f98-1a98-4a3e-b181-e1355d1fe66e.png6c0ca38c-f240-4b92-9e02-4ef2cef42c38.png
Aug 30, 2012 | Intertherm 56000 Btu Gas Furnace
My intertherm mgha is having pilot issues. The
The problem will be in what senses the pilot is lit. Either a thermocouple or maybe it uses an electrode and flame rectification. If it is an electrode you can try cleaning it. If it is a thermocouple you will have to replace it.
May 02, 2010 | Heating & Cooling
How do I light the pilot on my InterTherm MGBB 070 furnace? I have tried holding in the pilot switch but have had no success in getting the pilot lit.
Just to make sure you are trying to light the pilot, from the gas valve follow the small diameter pipe (1/8") to the pilot assembly. Where you should be placing your flame is above that point. Now with the gas valve knob turned to the Pilot marking, depress the know into the gas valve. Light the pilot. Check to see if it is lit and remain holding the knob in for 30 to 45 seconds. If the flame goes out as soon as you let out the knob, you will need to replace the thermocouple.
Oct 11, 2009 | Heating & Cooling
if there are two wires to gas valve check voltage between these two wires while the furnace is going through a start up if you never get a call or voltage to valve your control board is bad, if you are getting voltage ,your valve is bad
Sep 29, 2009 | Intertherm P3RA-048K Air Conditioner
No gas to light the pilot
ignitor coil could be bad again
Sep 11, 2008 | Heating & Cooling
Heating & Cooling Logo
214 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
