Question about Gateway GM5048 (6304) PC Desktop
I bought GM5048 from a friend. In good working order. Now I have everything hooked up & it keeps telling me Media test failure,-xe-MOF exiting boot agent-- O-bootable device-insert boot disc press any key. My problem is I need a boot disc=I didn't get that with it.
    President:
  • 1,768 Answers
1. You didn't specify if you are installing Windows XP or which operating system.
I assume that you want to install Windows XP. I am not sure as to the age of this unit and if it is compatible with the above mentioned OS.
2. If you have a valid key then any Windows XP Operating disk will boot your PC unit provided you have allow the device in the bios to boot from it.
3. You will need to select the CD/dvd device to be enabled for the pc to see the boot disk. Usually selecting F12 or F1 will allow you into the BIOS setup for this.
You will need to ask your friend for the user manual to follow the bios setup procedure. I don't think there is a user manual for this model online anymore.
Posted on Oct 05, 2010
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
I can not get my laptop to start up. When it turns on it reads PXE-E61: Media test failure check media cable PXE-MoF:exiting PXE ROM Operating System not found. Any ideas on what is wrong?
hi lawson1377,
it seems it can't find a bootable device in your laptop therefore trying to boot from network.
Get in the BIOS an see if the harddrive is listed and to see if the boot order is correct.
good luck.
Sep 08, 2010 | Toshiba Computers & Internet
Media test faiture, check cable error message ,
The error is related to your network interface card. In a lot of laptops this is integrated to the motherboard and can't be switched out at home. You will need to take the laptop in for service to have the card replaced.
Sep 27, 2009 | Sony VAIO Notebook
ACER 5315 IS DEAD ON BOOT UP IT DISLAYS PXE-E61:media test failure,chk cable PXE-MOF:EXITING BROADCOM PXE ROM
Sounds like it is trying to boot from network drive. Have you changed the bios boot order. If so, change it back to boot from hard drive first.
Jun 10, 2009 | HP Pavilion ze2000 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Gateway GM5048 (6304) PC Desktop Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
