Question about LG Televison & Video
Unit does not seem to respond to remote after approx 5 button presses. Once the unit stops responding then buttons on front also will not respond. 3rd unit now, all the same!
  • 27 Answers
SOURCE: Hughes SD-DVR40 has video delays
Video delays, running slow, and pixel glitches are indicators of Hard Disk Drive read and write errors. The shows you record are stored on a computer Hard Disk Drive within the DVR. If you have the original 40GB (35 hour) Western Digital Drive and it has never been replaced, it is a sure sign it is beginning to fail. You can either send it out and have it replaced or if you are electrically and mechanically inclined and want to try it yourself or have a computer genius living next door, the drive replacement is a simple process. You will need to obtain a pre loaded, pre initialized hard disk drive replacement for this Hughes DVR. You can purchase them online at www.weaknees.com. The smallest replacment is a 70 hour drive (80GB)They sell high quality pre configured Maxtor drives especially designed as replacements for DVR Drives. There are step by step instructions included with the drive. Any qualified electronics guru or computer tech should be able to replace the old drive with the new preconfiged drive. It is about a 30 minute job. Once installed and powered up the Receiver/DVR will act like it is a brand new receiver. You will have to call Directv to reauthorize your receiver again. If they ask, you can explain that you had a technician replace a faulty hard drive on your owned receiver and you need to reauthorize it. You will discover this when you power up with the new drive. The new drive should fix the delay problem. You will also need to set up your remote for your TV through the Remote setup menu again unless you remember the code (I can't). When you access the remote setup, the instructions will be displayed on the screen. Just scroll down to your brand of TV and input the different codes one at a time until you find one that works.
Posted on Mar 02, 2007
SOURCE: Front Display Panel Not Responding
the cable is torn that connects the lcd to the headunit.
Posted on Jul 04, 2007
  • 38 Answers
SOURCE: Freezes; sometimes resets by itself?
Most likely, it's your hard drive. It can be replaced, so you don't have to junk the unit.
Posted on Nov 28, 2007
SOURCE: Unable to power-up a Pioneer VSX-D714 unit
I am not sure if this is going to help or work for you but it worked for me. My amp D714 crackled a bit and then switched off completely. It would not power on again. I checked the fuses and tried the tone-standby buttons but that did not work. After a bit of searching on the web I thought I had lost my amp for good so I thought I would experiment a bit considering it's dead already. I opened up the top cover and started looking for dry joints. Then I came across the battery. It is located on the main upright circuit board. It says "Main" on it. The battery is a black circular battery that has 5.5v written on it. It is located in the middle of the board about 5cm from the front of the amp. With my experience with computers I decided to short out the battery. I did this by shorting out the two solders on the opposite side of the battery (other side of the board where all the joints are). I just held a flat screw driver on it for a few seconds. To my surprise I plugged the power back in and it just switched on. For now I am just running the tuner with all the speakers plugged in and all is working so far. I will see how long it last.
Hope this helps.
Posted on Nov 02, 2008
SOURCE: My TV has stopped responding to the remote control (and the universal remote) and the front panel buttons don't work
waynejman, I have the same exact problem, can you tell me what your outcome was?
Posted on Nov 16, 2008
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
My remote control deprogrammed and I lost the instructions. How do I reprogramme the remote desktop support? thank you
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thanx
Jul 28, 2010 | Brookstone 538744 Remote Control
The Onyko TX-DS595 receveiver won't respond to remote.
When unit is on hold down vcr button and press standy power button. display will read 'CLEAR". turn back on and see if remote works. note that this will erase any of your settings. Point the remote at any camera and look at the camera display. If you see a white light when you press buttos remote is working. Remove the top cover, remove front cover and resolder connections on remote receiver. If you intend to do this let me know and I can give you more details.
Mar 22, 2010 | Onkyo TX-DS595 Receiver
The unit doesn't respond to the remote. If I unplug it, it seems to reset. Sometimes it will not even respond to the power button on the unit itself.
9 times out of ten its the remote being the issue here try replacing the batteries ir cleaning the front where the remote sensor is that may help it. If you try-ed resetting the remote and still have issues this the remote will need to be replaced.
Thanks and do please click the accept button for my efforts.
Jan 02, 2010 | Nakamichi SoundSpace 5 Shelf System
Have rca tv combo unit have rca universal [rcu600m] cant seem to
RCA 000,006,011,019,027,034,038,044,046,088 <-----codes
Programming a Device using Code Search:
1. Manually turn ON your device (TV, VCR, Cable Box)
2. Press and "HOLD" CODE SEARCH
3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the device turns off, press and release ENTER.
7. With the device on, press any other button.
If the device responds, no further programming is required.
If the device does not respond, repeat steps 1-6.
Nov 09, 2009 | Televison & Video
The magnavox t.v. i'm trying to program doesnt respond to any of the jr300 codes, How do i do an all search
Try this as all remote controls work the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 28, 2009 | Jensen JR300 Remote Control
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Televison & Video Logo
22 people viewed this question
Computer Repairing
Computer Repairing
