Question about Krups Xp5240 Perfect Tamp Xp5240 Espresso Machine
The steam arm attachment for my Xp5240 espresso machine pops off.
4 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: After moving from MI to
OK this is the problem which you see in more machines when not been used for a while.
you will have to prime the machine. As far as I know you can get warm water from this machine too. first decrust the brewing head as that can be one of the problems. if you still have the maintenance booklet it is picture 21 ( i think)
If this one is equiped with the warm water function press the hot water knob and let it run through. If not try to make a cup of espresso with fresh coffee. This should work
Posted on Apr 21, 2008
  • 12 Answers
SOURCE: when I try to make espresso with my new XP2070,
David,
Most likely you have a faulty Solenoid Valve or the connection to the Solenoid Valve. This is a 3-way valve that directs the hot water or steam to the espresso head or the frothing tube.
Posted on Dec 18, 2009
SOURCE: Recently my Krups 4050 espresso machine starting b...
I have the very same problem and cannot find any solution for that. Any suggestion from you out there?
Thanks,
Peter
Posted on Apr 02, 2011
How to disassemble espresso machine.My gasket leaks
i think its not a gasket problem may be broken pipe or broken thermal block if you have a broken pipe it is due to not cleaning the filters you get an over pressure on the internal pipes and bingo water come out be wear of electric
Sep 13, 2015 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
Function switch is broken off just where it enters the body of the machine.
A parts sheet shows the switch as part of the front fascia. Unable to give you the part number, it depends on which market (country) it is for.
Sep 08, 2013 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
Krups XP5240 very loud pop sound while steaming
Take it back to the retailer, tell them about the noise and the water leak. It's under guarantee so you should not be looking for any self help solutions, it's faulty.
Mar 12, 2017 | Krups Coffee Makers & Espresso Machines
I have a Krups Espresso pump XP5240 and as like many people am having problems with the steam wand. The first one disintegrated in the plastic thread area. My new one keeps blowing off when steaming,...
My XP5240 also started blowing the steamer wand off after about 3 months of use, despite fiollowing the Krups cleaning instructions. Here's what I did to fix it.
A: The Problems.
The wand has three holes in the coffee end (center, and on each side). The center hole gets blocked with milk residue. This causes a pressure build up in the wand assembly, and eventually this is enough pressure to overcome the three gripping clips that hold the wand to the nozzle tube. I suspect this was an intentional design for safety. It's unfortunate that it also sprays the user with milk when it lets go.
The second problem is that removing the wand requires that the outer clip retainer ring to be slid down to release the clips. Many users don't realize this and try to pry or twist the wand off. This breaks the clips.
B: The Solution
The wand has to be regularly and throughly cleaned. Just soaking it is not enough. Do it this way:
1. Slide the clip retainer ring down, and then hold the steam tube and gently move the wand straight down. DO NOT try to twist the wand to one side, or you WILL break the clips.
2. Holding the ring, unscrew the coffee nozzle end. The wand separates into three parts: Outer tube, inner steam tube and decorative cylinder.
3. Use a needle or very fine wire (approx 0.4mm) to clear the three holes in the coffee end nozzle.
4. You now need to clear the metal wand tube of milk residue. I found that a 7/64" drill bit was perfect to do this, as it fits snugly in the tube. The amount of gunk removed was surprising.
5. Blow the tube clear from both ends. If it's clean, you will be able to see light through all three holes. If not, go back to step #3.
6. Make sure that there is no milk residue on the steamer tube nozzle where the wand clips on. Milk contains fat, and this is an unwanted lubricant.
After cleaning, my steamer works properly for several days. I also located a 21mm ID O-ring at the local hardware store to hook over the clips. This provides a bit more clip gripping pressure, but will still allow the wand to come off should steam pressure gets excessive.
Aug 02, 2011 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
FrancisFrancis x5 won't steam at all
check small allen screew on steam valve,maybe its just unscreewed
Aug 23, 2009 | FrancisFrancis! X5 Espresso Machine
Krups Xp5240 Perfect Tamp Xp5240 Espresso Machine Logo
41 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
