Question about GE Refrigerators
3 yr old ge fridge started clicking yesterday and everything got warm i unplugged and motor kicked on. Is this a compressor going bad?
    President:
  • 1,218 Answers
Good day,
It could be, as you said, the compressor going bad or it's possible the start relay clipped to the compressor body is failing.
If it repeats the problem, you could unclip the relay from the compressor and replace it with a new one.
However, since you still have 2 years factory warranty on the compressor I would suggest you call GE or a GE factory authorized service company. If it's the relay, you will be charged for the repair, but by doing that you will maintain the integrity of the compressor warranty, especially if the repair turns out to be short lived and it turns out the compressor needs to be replaced.
Posted on Oct 05, 2010
GSS25KGMB GE Side by Side, Ice is melting then refreezing in icemaker tray
i don't know how old your fridge is but on older ge's if the evap fan motor was bad they wanted you to also change out the motor board.first thing unplug it,look at the board the newest boards have 7 relays on them,if yours doesn't i would change the board out,this is what powers everything in this machine,compressor,fans everything,so if i had this issue i would change out the board or it sounds like you could have a bad compressor but that would be new fridge time, part wr55x10942 now the newest board is wr55x10942p i haven't seen one of those yet but i looked up a fridge yesterday and saw that so they made more changes to this board.good luck
Nov 18, 2017 | Refrigerators
My GE bottom Freezer Fridge model pfse5njwdss not cooling at all. both fridge and freezer are not cooling, the lights are on and a very low sound exists, but not cooling. As if its not on.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Aug 30, 2011 | GE Refrigerators
A few days before we discovered that the fridge wasn't working properly, I heard intermittent clicking sounds. The motor at the back and bottom??(not sure exactly where) of the fridge sounded like it was...
IF YOU HEARD THE UNIT CLICKING FROM THE BACK AND THEN A FEW MINUTES LATER DO IT AGAIN MOST likely you have a bad start relay on the compressor and the overload device on the compressor is kicking out... whirlpool is known for this particullary problem and it normally is a easy fix... go to www. repairclinic.com or apdepot.com and you should be able to enter you model number on one of those sites and your looking for the compressor relay ....
to varify it is bad and prior to buyiong pull it off should be 2 maybe three wires in some cases and shake it...if the relay rattles like something broke thats your problem.... also unplug the unit the more it trys to start with the bad relay you could eventually damage the compressor if it has not already..... good luck
Jan 03, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
My fridge wasnt cold yesterday but the light was on and the freezer worked but this morning the freezer has started to defrost and everything was warm in the fridge
If you cant hear the compressor running and he fan under the fridge and in the freezer compartment are not running. The problem would be your defrost timer has quit on the defrost mode. Your defrost timer should be located in the fridge side behind the back plastic liner or if your controls and light are in the center top it will be there. The timer is plastic with a metal motor on one side. There is a shaft in the center that a flatblade screw driver will fit in turn it and you will hear audible clicks and the fans and compressor should kick in. I hope this helps. If the fans are working but the compressor is not the compressor is bad or the start relay on the compressor may be bad it is located under a plastic cap on the compressor and is about the size of a nickle and is connected to one of the 3 prongs coming out of the compressor. Remember to always unplug the fridge before working on it. good luck
Aug 18, 2010 | Refrigerators
GE TBX25ZLB Refrigerator Compressor won't Engage
Part number for compressor relay is WR7X222. However, you have a very old rotary compressor there and most likely it went bad. I would just buy a new fridge. Don't waste your time/money. The fridge is too old.
GE refrigerator repair in orange county, ca
Feb 06, 2010 | Refrigerators
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Just got back from vacation opened fridge door and wow, was greeted with god awful smell everything hot, i noticed the freezer temp was on zero, possible due to my four yr old but know cant get the...
if the freezer is at o then the compressor is working and frost buildup in freezer back panel check to make sure the cooling fan is working on the compressor area
Aug 19, 2009 | GE Refrigerators
GSH25KGRBB ge fridge
THE P.C.BOARD. UNPLUG FOR AFEW MINUTES THEN TRY IT. IF NOTHING, REPLACE BOARD.
Jun 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FRIDGE NOT COOLING
sounds like the starting device for the compressor clicking on/off not always starting, hopefully under 5 years old cause sounds like a bad compressor(full 5 yr warr on on that)
Mar 14, 2008 | Frigidaire FRS26R4C Side by Side...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
