Question about Porter Cable Cable Commercial Pressure Washer PCH3200
My porter cable 2400 psi pressure washer will not start. has honda engine gc160. pulled plug and put up against frame and it has spark. It's full of oil.
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
peterrance19
  • 399 Answers
SOURCE: Porter cable pressure washer starts great, but
check the seals and o rings on the connections could be sucking air
Posted on Nov 13, 2009
mkh5094
  • 145 Answers
SOURCE: What type of oil is needed for a Honda GC160 Power
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Posted on May 28, 2010
  • 760 Answers
SOURCE: what typ of gas do i use
Regular gas 87-89 octane works fine.
Posted on Jul 14, 2010
  • 760 Answers
SOURCE: engine manual for the Porter Cable pcv 2250 pressure washer
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
Posted on Jul 23, 2010
Black max 3000 honda pressure washer won't start
You need two things for the engine to start, spark and fuel. Pull the plug, hold it close to the engine and pull the starter cord- check for spark. If there is spark (most likely there wil be spark), then it is a fuel problem. Try a little startiing fluid into the breather and see if that gets it to start. If that works, then the problem is in the carbureator - it probably needs to be rebuilt if the engine has been sitting for a while.
Apr 13, 2014 | Honda Black Max 3000 Psi Pressure Washer
Honda gc160 engine on 2500 psi washer, no spark?
new spark plug? flooding may have fouled the old one.
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Rope hard to pull
if there is an auto shut off adjust the cable its not pulling all the way open
Mar 08, 2014 | Karcher 2500 PSI Pressure Washer
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
What is the spark plug gap?
Hi Mike,
If you can identify the model of Honda engine on the washer, you can download the service manual from this webpage:
http://engines.honda.com/models/application/pressure-washer
Hope this helps!
Apr 06, 2011 | Porter Cable PCH3200 Commercial Pressure...
I can not pull the string to start the engine of power washer
Try removing the spark plug then pulling the cord! If the cord pulls then you cycle the engine a couple of time to see if fuel is coming out of the spark plug hole! If no fuel present replace spark plug and try starting the engine. always have water running through your washer before you attemp to start!
Jul 17, 2010 | Honda Pressure Washer PSI 3000
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Jun 27, 2009 | Honda Garden
Porter Cable Cable Commercial Pressure Washer PCH3200 Logo
221 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
