Question about Breville ESP8XL Espresso Machine
Hi I have a Breville BES200XL Espresso Machine in the office. It's only a couple of months old. everyone uses it and they are saying that a little water is coming from underneath. Now it's not sitting on exactly a flat surface. the table is a little warped. told the people to check the drip tray and make sure the water tank is firmly in place. the only other thing i can think of is because not sitting exactly proper. the vibration when the machine is on is causing something underneath to loosen?? regards Art
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
  • 1618 Answers
SOURCE: My Breville Venezia Espresso machine leaks once in
Sounds like the brew solenoid is leaking.
Posted on Nov 12, 2009
SOURCE: how do I get my breville cafe roma espresso
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Posted on Dec 28, 2009
  • 15 Answers
SOURCE: I've A Breville 800 esxl espresso machine.When mak...
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Posted on Nov 27, 2010
SOURCE: Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
Posted on Sep 18, 2011
I have a Breville BES200XL that does ot start anymore even though the light goes on.
Jan 02, 2015 | Breville Coffee Makers & Espresso Machines
My bes870 will not create enough pressure to form a good crema ,grind setting is 2-3 .Amount of ground coffee is correct but the pressure does not go much past the pre fusion pressure .The machine has...
For an 8 month old machine it should still be under warranty unless commercial use. (similar unresolved Q posted
Jul 20, 2014 | Breville Barista Express Espresso Machine...
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
My Breville is only a couple weeks old. Over the ...
Try completely unplugging your pot and then plugging it back in. It is possible that this will reset the programming in your coffee pot. If this doesn’t work, I recommend calling Brevell customer service and they will either help you or probably send you another pot.
Nov 05, 2017 | Breville BKC600XL Coffee Maker
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Chrome on steam wand wearing off
Posted by
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
No steam or pump noise
get a used starbucks barista by saeco for a couple'll be pleased. (know i am-and i only paid $25 for my year old breville esp8xl POS). verify it works-it will probably last longer & perform better. if inclined/capable, maybe you can replace the pump yourself (a new one's prob in $35-$40 range; if more, scrap the machine or sell it "as is" for parts & put the money toward a better machine. good luck!
Oct 07, 2008 | Breville ESP8XL Espresso Machine
I would like to buy a breville cappuccino maker but hear the dial at side gets stuck and breaks easily,even when cleaned well after use. Has this been rectified. Doreen
Hi, apparently Brita, that owns Breville, did not fix the problem yet.
I can see that complains keep coming.
The problem is apparently on CM8 and CM9, the more expensive Cappuccino Maker BES200XL
does not have the problem.
One suggestion, Breville are nice budget coffe maker, if you want to spend some mor money on a better product buy a Gaggia or something similar. Italian coffee makers are usually the best for espresso/capuccino. If you want a Breville buy the ESP8XL Espresso Machine.
Here is another good brand.
Sep 13, 2008 | Microwave Ovens
Makes espresso, coffee, water, but will not steam
The pump has gone bad - through use. This is a common problem, and has to do with the "seals" that are in the pump. Since the pump generates high pressure and heat, over time, the seals will fail, and will be unable to generate enough pressure and heat to create steam. The only remedy is to have the pump replaced through the Breville Out of Warranty repair centers.
Dec 11, 2007 | Breville Die Cast 800ESXL Espresso Machine
Breville ESP8XL Espresso Machine Logo
276 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
