Question about Technics SL-1200 Turntable
The speeds will not match - Technics SL-1200 Turntable
    Sergeant:
  • 357 Answers
Can you be more precise. At the moment it sounds like you cant beat match. that is not the turntable's fault
Posted on Nov 05, 2011
I just replaced the drive motor. How do I calibrate the treadmill before use?
Hold the stop, + speed button and attach the safety key. You should get the software version on the speed window. Continue to hit the stop button until you see zeros on the incline, speed, and heart rate windows. Your incline and speed numbers should match, if not increase the speed to 10 MPH and turn the POT resistor until the numbers match on the windows. The pot resistor is on the Motor control board
Mar 03, 2015 | Proform Exercise & Fitness
Error code co238
C0238: Wheel Speed Mismatch. This error code will also disable the ABS and any traction control system.
The front and rear detected speeds are not within 10% of each other. The vehicle expects all 4 wheels to be the same size. If the the front pair and back pair are not the same size: EBCM tire size needs to match the front, and PCM must match the rear.
It could be related to an ABS system failure.
Nov 22, 2013 | 2003 Chevrolet Astro
Can i combine 2 different DDR2memory RAM on two slots??? my motherboard can carry DDR2-667 and DDR2-800,,, i'm really confuse if i can add 1gb of 667 and 1gb of 800 and together they can run smooth..
They will run together but at the slower speed so you are better to match speeds.
I would sell the 667MHz stick and buy the matched 800MHz, its alot quicker.
Jan 14, 2010 | Intel DG31PR Motherboard
How to match a 327 motor with 95 trans am 6 speed
nothing it will bolt right up, same block.
Sep 18, 2009 | 1995 Pontiac Trans Sport
Speed of printing barcodes
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Feb 02, 2009 | Zebra Stripe S600 Thermal Label Printer
RANK GAMES FREZZES AFTER TIP OFF BUT NON DURING NON RANK MATCHES
Might be something wrong with your connection to the server. Speed it up by deleting any cookies, Temporary files or just try to speed the connection up anyway you can.
Sep 15, 2008 | 2K Games NBA 2K8 for Xbox 360
Toyota caldina 1998 GT
must put chains (if you really need them) on all 4 wheels of your all wheel drive car to prevent a speed mis-match between front and rear...a mis-match can destroy the gearboxes over prolonged use. use chains that have many cross links to lessen the effect of any speed mis-match
Jul 03, 2008 | 1998 Toyota Corolla
Sound doesn't match tape speed
either your dd cylinder(head) is faulty or your posts need alignment. panasonic technician needs to look at the camera.
Apr 11, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Technics SL-1200 Turntable Logo
29 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
