Question about Mtd Oem Deep Deck Belt 46"
I replaced the drive belt, now the cutting blades will not engage
  • 203 Answers
Sounds as though you have the belt on improperly. Or is the clutch not engaging to turn the belt?
Posted on Oct 05, 2010
Blades will not engage. belt ok. can turn blades by hand.belt did not smoke. just stop cutting
the top drive pulley on your deck is stripped,take off the nut and check it,make sure you replace the lock nut too or it will happen again
May 04, 2015 | Garden
When I engage the lever for the blades to start cutting, the blades don't engage
Check for bad or loose belt also see if you are missing a shear pin in one of your drive pulleys. See if your lever to engage the blades is actually putting driving pressure on the belt. Could be a spring is missing as well.
Apr 12, 2015 | Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The belt that drives the blades for cutting has broken and I need to replace it. I have a Craftsman LTX1000 lawn tractor and I've misplaced the manual. The belt is 96" long. Not sure where to...
With the mower off.
Look on top of the deck.Find the pulleys for the blades then find the engine pulley.There should be one more pulley that is the tension pulley.Watch that pulley as you pull the engage blade lever,while still turned off.The belt will go on the blade pulleys,and the engine pulley,it needs the tension pulley to push it tight.So you need to make sure it goes on the inside of the tension pulley.If you get the belt on and it does not engage,just remove it and replace it on the opposite side of the tension pulley.
May 12, 2011 | Craftsman 42 in. Precision Cut Plus 24hp...
My Craftsman riding mower runs fine but when I try to cut thick or tall grass the blades slow down and stop cuting, I replaced the belt thinking the belt was worn only to find I still have the same...
well yep it is,,,look at the deck first to check its not tight to turn look for sezed up bearings,,,then check that the drive belt/s are tight and not flopy and slipping also it would be a good time to check the cutting blades they need to be sharp and not blunt or they strain the belts and start them slipping too also the engine wont like the extra load put on it
Jul 28, 2010 | Craftsman Garden
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd Oem Deep Deck Belt 46" Logo
113 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
