Question about Geovision GV-650 BNC (GV6504) Video Capture
Sony dome cameras connected to geovision GV 600. One of the camera is blurry. I tried to change camera but no improvement. it was fine when we installed it, can some one help me??
  • ferdi_baba May 28, 2008
    sony dome cameras connected to geovision GV 600. one of the dome camera is very blurry, i tried to replace but still it is blurry.
    can some 1 help me???
  • 423 Answers
You need to back focus the camera. That means you have to adjust the distance between the chip and the lens. There should be an adjustment on the camera itself.
Posted on Feb 15, 2009
Have geovision gv-600, the video lost on 5 out of 10 cameras?
If you confirm this is the card and not the cameras, then you may have some bad ports. You may need a new card. It happened to me at a customer after a lightning strike. Although mine was 4 cameras (1-2-3-4). You can also verify that the cameras are activated on those channels. That would be the easy fix.
Apr 11, 2013 | Geovision GV-600-16 Digital Video Capture...
I have gv 800 card using V8.5 software, i have five cameras connected but it only displays 4
This is not a big issue u ant watch 5th camera coz u had stopped other 122 cameras from working in GV eries you are allowed to stop remaining cameras from working to avoid video lost beep and video lost screen you can again start remaining cameras from here:in main menu (configure) 2nd option from top CAMERA/AUDIO INTALL ===> click on activate ===> activate the cameras as muich you want hope my post helped u
Dec 28, 2011 | Geovision GV-800-16 Video Capture
Will the GV-FE110 Fisheye IP Camera need the Capture Card?
No. None of the IP cameras require a capture card. Instead the included Geovision software can be used to record the video. That's the beauty of Geovision. Good software at no cost when you use their cameras.
Jul 20, 2011 | Geovision Gvfe110 13 H264 Fisheye Ip...
GeoVision GV-BX110D cameras unexplainably changing from color to black & white. Geovision NVR
This has to be caused by either a setting in the camera or the light level. If this is not the case, you probably need to RMA the camera. This is not normal unless the aperature is set wrong.
Jun 02, 2011 | Geovision NVR Lite Box Camera System 4 X...
Cant view vedio log on GeoVision GV-600
Okay - try going into the software directory and delete the files maked .db there should be one for each camera. Then start the software and try it again.
May 14, 2009 | Geovision GV-800-16 Video Capture
Camera pictures are jumping arroung on the geovision screen.
try calling up the system on the 16 screen to see id if thy still jump around if not and its only on the single screen then u have the camera rotation on wich u can turn off. its at the bottom on the right it looks like a monitor with arrows pointing to the right
Dec 17, 2008 | Geovision GV650-8 GV-650-8 GV 650-8 60FPS...
Gv-800
This problem could be because of the GV card version not compitable with GV main systems software you install please check the hardware version of the GV card and compare for compatibility. East way out downgrade to lower version of software. for example if you have version 8.1 install then install version 7.0 or something like that.
Aug 27, 2008 | Geovision GV-800-16 Video Capture
Geovision GV 800 video lost
Uninstall and re-install the drivers first. Let me know what that does.
Thanks,
Lee
Jun 20, 2008 | Geovision GV-800-16 Video Capture
Geovision GV-650 BNC (GV6504) Video Capture Logo
127 people viewed this question
Top Geovision Televison & Video Experts
Rommel Balcita
Mark Magill
Mark Magill
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
