Question about HP Pavilion dv6000 Motherboard
Replace mother board on HP dv6000 the drive fail as well and dont have restore disk , problem I am running into is It wont recognize the sata drive , I have look around for the drivers to use during the install phase but have not found the correct ones to solve the problem. Thanks Benjamin
    President:
  • 1,768 Answers
1. You didn't designate if this is a DV6000 notebook COT etc.
The drivers can be obtain from HP
here is the site for support and I think that if you called you could get the restore disk sent to to you for a small fee.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=dv6000&submit.x=10&submit.y=8
Posted on Oct 05, 2010
Connect sata disk drive to bi directional ide to sata adapter
Just asking, you have got a power connexion to the drive as well, haven't you?
Dec 08, 2013 | Computers & Internet
Diagram of USB and hard drive slots on H-RS880-uATX (Aloe)
the best way to find out the connection order is in the bios. sadly i dont have your exact mother board on hand to look at the bios and tell you exactly where in the bios it is. i do not know how to map usb slots from my own experience maybe someone else knows a sure fire way. you can get an idea from device manager and plugging in usb devices into slots one at a time and make your own map based on which slots are changed in device manager.
Sep 10, 2012 | Foxconn H-rs880-uatx Hp Aloe Motherboard...
I had a new hard drive and mother board replaced in an HP G60-230US laptop. After the these replacements, I am not abe to use my webcam. It states that it doesn't recognize the webcam. There is...
I have one possible solution, but it may not be the answer you need.
In an HP, if you replace the hard drive and the motherboard and don't run the DMI (it digitally signs the motherboard and hard drive), it may stop you from loading stuff. I know for sure unless you run this your restore disks will not work.
Something to consider. You'd have to contact HP if this is the case.
Jul 25, 2011 | Computers & Internet
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Any sata hdd can't dected by the mother board but any sata dvd dected by the mother board. what kind of procedure i followed now?
Your motherboard CAN detect a SATA device.
Your motherboard DOES detect your SATA optical device.
Your motherboard does NOT detect your SATA disk-drive.
This suggests that your disk-drive is "dead".
Exercise the WARRANTY on it, to get it repaired/replaced.
Or, if the warranty has EXPIRED, purchase a new SATA disk-drive.
Feb 03, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My hp compac come on powers up, but will not go on line, will not recognize the disc drive , will not recognize any USB ports and when I go to shut down, it will sit on the "shutting down" screen for...
just a mobo huh, no PC, there.
so what PC did it come out of???? HP what? desktop .
turns on, ok
will not recognize the disk, (what disk? what drive, what disk,??)
floppy, PATA HDD, SATA HDD, or CD drive.?
will not recognize, USB ports. (in BIOS or in Tne OS)
what OS, windows 3.1? what/? what Operating System??????
what OS will not shut down, and installed by whom and what media>?
take this unstated PC and install the OS, as it came new.
This PC is so old its not supported by HP, now.
so find and install disk (media) and re-Install the OS.
Fresh.
there it is, Google fails to find the match to any HP PC model name.
HP has zero data on it, now, its too old.
Jul 13, 2017 | HP (D7580-60003) Motherboard
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
When i start my hp pavilion dv6000 it reboot again and again.it give message (PXE-E61 media test failure, check cable) and another (PXE-MOF: exiting PXE ROM) plz solve my problem
The DV6000 series units come with SATA Hard Drives and are apted to go south now and then.!
Before replacing the HD I would clear the CMOS and check HD thru BIOS utility.
This utility will in most cases take about 1hr. if you have a standard size HD. Longer if larger, anyway, it will tell you before you start and if the dive fails, you will know soon enough. This sounds like a boot partition problem in your HD but you have 2, 1 in the front and 1 at the end, that may just be corrupt.
If you have not formated drive since you have purchased the unit, you may still be able to re-install from the restoration partition.
If not you will have to replace hard drive and install from restoration disks. HP offers these disks for the 6000 series units for about $15.00 US
You will have to update your BIOS if you have not done so already. You can check to verison by hitting F10 at first screen.
P.S. SATA drives are cheep enough about $60-85 depending upon size.
Take care Good Luck
John@johnrraycomputer.com
Jun 06, 2009 | HP Pavilion dv1000 Notebook
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
HP Pavilion dv6000  Motherboard Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
