Question about Brother IntelliFAX 1270E Plain Paper Fax
When faxing or making a copy the paper that you put in to fax or copy won;t go through unless you open up the front of the machine and then after it goes through it says Paper Jam.
  • Anonymous Mar 25, 2014
    Won't Copy Paper
    Scholar:
  • 159 Answers
Most likely, the document sensor actuator is misaligned on it's rocker. This is quite common, it is fairly easy to reset, but be careful you don't break it.
Posted on Oct 06, 2010
  • bosiason473 Apr 11, 2011
    Tell us where it is or what it looks like so we can fix it. We're not techies, so we don't even know what we are hunting for.
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
Streaks on faxs sent
Are there streaks on the copies you make?? Print out a report or list from your machine and see if the streaks are on the printed pages.
Open the feeder from the top of the machine...you will see a thin strip of glass maybe 1/2" wide running from the rear of the machine to the front..odds are there is glue/dirt/corrector fluid or some other dirt on the glass. Clean this off..once you can make a clean copy you should be sending clean fax's.
Oct 17, 2010 | Muratec F320 Plain Paper LED Fax
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Problems with copying
Pull front of fax machine open
look down
clean the little glass ****.
Jul 19, 2008 | HP 1220xi Plain Paper Inkjet Fax
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Copies with the Brother Fax-T104
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Dec 21, 2007 | Brother FAX T104 Plain Paper Thermal...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
