Question about Magic Chef CER1115AA Electric Kitchen Range
What do i do about an F1 alarm that won't quit??????
  • Magic Chef Master
  • 3,051 Answers
Hello there:
this annoying alarm and the f1 code is reffering to the
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, you will need to remove the back panel that houses the electronic control unit then disconnect ribbon strip. going to it and retry the oven If NO fault code, replace membrane, otherwise replace board
Posted on Oct 05, 2010
The F1 error code is lite and alarm noise won't shut off. turned off breakers and the alarm stopped upon turning back on but F1 lite is lite.
With your model & Serial number you should be till able to order the EOC (Electronic oven control). But they are not cheap.
Mar 17, 2015 | Ovens
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
I have a maytag oven with f1 and f3 codes what
F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
Nov 09, 2009 | Kitchen Ranges
GE oven functional code F1 appears.
Hello, I come across this problem quite often, The f1 error code does not always follow that it is a bad EOC (Electronic oven control) This could also be a problem with the touchpad. The way to figure which is bad is turn electric off, access the EOC and pull the wire harness/ribbon tape for the touch pad. Reassemble the range and switch power back on. If you are still getting the F1 it is the EOC..If the F1 clears then your problem is with the Touchpad. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Aug 18, 2009 | GE Kitchen Ranges
F1 and alarm going off .turned power off and and on .kept flashing f1 and alarm noise
normally the f1 code stands for failed matrix in the control brd behind the panel. by removing the panel, after disconnecting power you should find a tech manual which should show the code and solution
May 19, 2009 | Ovens
Intermittent alarm
pull your range out there is a tech sheet on the back that will tell you what the reason for the f1 code is. you can go from there.
Jan 03, 2009 | Magic Chef Kitchen Ranges
F1 Alarm @ rinse cycle
F1 code = Primary Control Failure. Replace the machine/motor control assembly. If you use a screw driver in front of the machine to open the top you will find a repair manual on the inside of the front panel. or depending on the model, you can even unscrew the bottom and find the manual.The manual inside is actually meant for technicians.It contains the error codes and instructions related to them.will be looking forward for your comments if there is any further problem in this.
Dec 15, 2008 | Whirlpool Washing Machines
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
Magic Chef CER1115AA Electric Kitchen Range Logo
241 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
