Question about Mk Diamond MK - 770EXP
How do i get brushes out of my mk 770 tile saw with black switch
  • 333 Answers
Http://www.ereplacementparts.com/diamond-mk770exp-114-wet-cutting-tile-saw-parts-c-9396_9399_9401.html
Not positive but here is a website with a diagram and parts if it helps.
Posted on Oct 05, 2010
Why does my mk 770 blade wobble when cutting
Most likely if you put it down on a flat surface you will find the blade is no longer flat and true. Patient tapping with a hammer can true it back up, or if you don't have the patience for that and it really is the blade and not something else, then a new blade might be the way to go.
Oct 26, 2015 | Generic MK 770 SMR1506 24 Amp Tile Saw
My MK-100 does nothing when I turn on the switch.
Check the brushes for the motor. very common problem in electric motors. It should look like a slotted head of a screw on the side by the motor. Only its plastic and about the size of a dime. After removing the brush, or magnet is what it actually is, replace it. Very cheap to replace and most hardware stores carry them. Hope that helps. Otherwise the switch is bad
Jun 27, 2012 | Mk Diamond MK - 170 Wet Cutting Tile Saw
My MK370 tile saw has a burning smell and it is making a slight banging noise every 7-9 seconds. The saw is cutting tile fine otherwise.
The problem could be bad brushes. Otherwise, you are probably burning the windings inside your motor. The slight banding noise could be an issue with the bearings in the motor itself. In which case you will soon be replacing the motor, so... we'll hope the brushes prove bad.
Assuming the motor has brushes, there will be 2 semi-large buttons on the motor (one on each side). They are screws. Remove them and beneath each one is a "brush". They should be long, hard, crack free, and smooth on the bottom where they touch the rotor. If not, then replace them. Almost all motors used for tools have brushes and some motors require disassembly of the motor itself to replace the brushes, but in your case, it should be an easy job. I can see one of the buttons on the Amazon picture.
:o)
Jun 03, 2011 | Mk Diamond 159943 MK370K 114Horsepower...
I am trying to find an wiring diagram for a tile saw mk-660
Here is the website you need to find the manual and wiring diagram for your saw
Hope you find what you are looking for
http://www.mkdiamond.com/tile/saw_660.html
Nov 30, 2009 | Mk Diamond MK - 660 Electric Tile Saws
Shorting out
have you checked the brushes ???
Aug 06, 2009 | Wet International Mk Diamond 153330 Mk 660...
Water flows for cooling but saw does not rotate
check to see if the motor has overload reset button on it (red) usually the water is only pump portion of circuit and can run independent of motor circuit , if not check wiring to motor circuit
Nov 20, 2008 | Mk Diamond MK - 770EXP
Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
Aug 27, 2008 | Mk Diamond MK 101Pro Tile Saw
Mk Diamond MK - 770EXP Logo
201 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
