Question about Dell Dimension 8400 PC Desktop
I have a Dell 8400 that will not start up. The little green diode on the mother board lights, but nothing else happens. I read a post that suggested that I short the green and black wires of the motherboard power connector and plug in the power. Still nothing happens. I had the power supply tested with one of the handheld testing devices at Comp USA and they said it was good -- it did run and turned on all theiry green lights. But it still does not work for me. I also removed all cards and all memory and all cables disk cables. still nothing but the little green led. Can you help?
  • 2 more comments
  • bobteague200 Oct 05, 2010
    I still have no response. The power supply fan does not start. Absolutely nothing shows any response except the little green led beside the 24 pin connector, when the power is plugged in. absolutely nothing else. As I mentioned before, a Dell rep on the Dell users forum suggested, to others who had the same problem, that they put a shorting wire from the green wire to one of the black wires in the mother-board power connector (the 4 pin connector). That was supposed to make, force, the power supply run, but in my case it did not help. And yet, when Comp USA used the power supply tester, it showed that the power supply was good. Is it possible it is still bad in a way that the test tool did not check? Someone else, in a blog, suggested that the only real way to test a power supply is to replace it with a known good one.?? I don't have a known good one and I hate to buy one when Comp USA said this one is good. The problem started when I went on vacation. The system was working fine before. When leaving I shut down the computer and unplugged the UPS so that lightning could not run in on it. When I returned I plugged the UPS back and hit the start button on the 8400 -- but nothing happened, not a sound or anything. So, what else would you recommend?
    Thanks, Bob
    When I plug the jumper as you have shown, with the mother board connectors disconnected from the motherboard, then the fan turns. But if I plug the large motherboard connector into the motherboard, with the jumper in place from the back of the plug, then the fan does not start and only the green led turns on. So it appears that a signal from the motherboard is inhibiting the power supply.
  • bobteague200 Oct 06, 2010
    I have made a picture, but it is too large to send in this comment space. The maximum for here is 150KB. If you send me your email address, I will gladly send you one. My address is bobteague2000@gmail.com if you want to send your address that way.
    Otherwise, I am not sure what that accomplishes, since it is totally impossible to connect any of the connectors to the motherboard incorrectly. They are keyed and all of unique sizes. I do not have the jumper attached to the connector now, so that did not affect and does not now affect the operation.
    Thanks, Bob
    The solution has led me to a solution to the problem. Nonontech did a great job and my thanks to him for sticking with me.
  • Dell Master
  • 4,737 Answers
First remove the power cord from the back, disconnect everything, including mouse, keyboard etc..etc... now open the case and disconnect/unplug all the inner components..like fan connector, cpu, ram, front panel connector, usb, audio, PCI, etc..etc..
Refer this:
[If there's Add-On graphic card, use the On-board one.]
Note all the connectors/plugs and their respective corresponding male/female connectors/slots. Once you are done disconnecting, remove the Bios Battery. Leave it outside for few minutes. Now install the battery, cpu, connect the cpu fan, install the ram (if there are multiple ram sticks, install only one of them), connect the hard drive, the front panel (only the power switch). Now connect both the power connectors (see above diagram, i've circled the power female connectors with red circles, there are two connectors..).
This is the labelled diagram of your motherboard.
Now power on the Machine and see what happens, if it's ok.. Switch off the machine, reinstall the remaining connectors and components one by one and power on the machine everytime you connect/install a component. Don't ignore this, otherwise you'll skip the most important part and you'll not be able to find out the culprit.
After several attempts and reboots, you'll see which one is causing the problem and you have to get rid of the particular component.
Let me know the result.
Good luck.
Thanks for using FixYa.
Posted on Oct 05, 2010
  • 4 more comments
  • Lebanon Raingam
    Lebanon Raingam Oct 05, 2010
    Ok.. then, let's check the power supply (SMPS). Actually we can't judge good or bad, it depends on the usage, environment, or sometimes a luck :-) [I don't know how to say that..]. These days, Electronics are only warrantied, not guaranteed.. and that's the greatest problem for end users, but if Producers give guaranty, then they will loose many items..
    Well, look at the pic below:
    One end is connected to the Green and the other end to the black and in between them, there are two female connectors.. I hope you understand upto that. Take a tiny wire, but it, make the ends exposed and insert the ends as shown above. (Remove the four pin power connector from the motherboard). Now plug in the power cord and see if the SMPS' fan is running or not. If it doesn't, then the culprit is the smps.
    Once again very good luck.
  • Lebanon Raingam
    No you shouldn't connect the Power connector with the wire in that way, it was only to check the SMPS. Well could you please upload a picture of the Motherboard with all the connections intact? If it's possible, will be much easier for me, if in case there's a small mistake with the connection. As you've mentioned, it shouldn't die :-) like that...
  • Lebanon Raingam
    Lebanon Raingam Oct 06, 2010
    Done on the other side.. :-)... Let me see.... only to clarify... Thanks.
  • Lebanon Raingam
    Now let's try this.. remove/disconnect/unplug everything from the motherboard, i.e. Ram, IDEs, SATAs, CMOS Battery, front panel, etc... Keep the CPU and CPU fan connected, both the power connectors connected. Also remove all the external peripherals, mouse, keybaord, monitor, etc..
    Connect the power cord, look carefully on the Front Panel connector, and short/jump the pin number 19 and 20
    Description of the Pins:
    1 INTRUDER 3 -> INTRUDER 3, FNT 32
    2 5v Power -> FNT 3, FNT 4
    3 5v Power -> FNT 2, FNT 4
    4 5v Power -> FNT 2, FNT 3
    5 LED VCC -> CTRL 6 thru R19,CTRL14 thru R20
    6 GND LED ESUP
    7 LED PSON
    8 INTRUDER 5 -> INTRUDER 5
    9 GND -> GND
    10 GND? -> GND?
    11 GND -> GND
    12 USB 1 (bottom) Data - (white)
    13 USB 1 (bottom) Data + (green)
    14 GND -> GND
    15 USB 5V+ (both ports)
    16 GND -> GND
    17 USB 2 (top) Data - (white)
    18 USB 2 (top) Data + (green)
    19 GND -> GND
    20 PWR SWITCH LEFT SIDE (Both) --> CTRL 2
    21 Pin removed -
    22 HDD LED NEG -> CTRL 4
    23 PWR LED GREEN POS -> CTRL 5
    24 ESUP LED NEG -> CTRL 13
    25 GND -> GND
    26 ?
    27 PWR LED YELLOW POS -> CTRL 9
    28 ESUP SWITCH RIGHT SIDE (Both) -> CTRL 8
    29 GND -> GND
    30 INTRUDER 1 -> INTRUDER 1
    31 EXT_SPK 2 -> EXT_SPK 2
    32 INTRUDER 3 -> INTRUDER 3
    33 EXT_SPK 4 -> EXT_SPK 4
    34 EXT_SPK 1 -> EXT_SPK 1
    Follow ups will next comment.....
  • Lebanon Raingam
    This is the final step and we'll definitely find out which component is the true "culprit". Remove the installed power supply, plug-in the connectors and power check with the new SMPS. It should at least show something, good or bad.
    Optional: If possible, check or try with another Processor, this is very rare but we need to try it this time.
    If either of these don't seem helpful, I would suspect the graphics card or the BIOS chip or in rare cases could be the ChipSet Module (IC). You'll need to take it to the service center or call Dell.
    I hope we've done all the troubleshooting methods.
    Let me also highlight the possible causes,
    1. Reset Button, when the reset button is stuck or not working or shorted, this happens (and we've known that this is not the case)
    2. Ram, when one or more Ram stick/s is defective, this could happen (neither this is the case)
    3. When CPU is overclocked, this will be cleared after the CMOS battery is removed and left for few minutes outside. (neither this)
    4. Power supply (checked and confirmed), but we can only test it's status, jumpering the green and the black wires.
    5. Front panel connector or front/ usb connector or etc..etc.. faulty... (no suspects.)
    6. Processor.
    etc.. etc..
    So the things we haven't tried out are, Video card, Bios (which is not possible from end users).
    Once again, Good luck...
  • Lebanon Raingam
    You are most welcome Bob... and once again thanks for using FixYa.
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Dell 8400 dead
Can you tell if your hard drive is running? You can here it or feel it spinning. Are the fans running? If no, I'm 99% sure you need to replace your power supply and/or motherboard. This kind of thing usually happens after a power surge.
Sep 24, 2007 | Computers & Internet
Need some help please. Shuttle sn27p2 nearly 4 years old. Problem: Green led on mother board on, pressing the power switch and nothing happens at all, that?s no fans, no light on power switch nothing....
Your symptoms make me believe that you're out of Power Supply. Does this happen all of a sudden?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 22, 2010 | Shuttle XPC SN27P2 Barebone
Dell Dimension 8400 won't turn-on/respond after having problems
i recommend u to install windows7 ultimate
it will automatically install drivers and solve driver related issues.
Mar 29, 2010 | Dell Dimension 8400 PC Desktop
Not reading memory cards. No screen at all
It might a month board issue then. If its not under warranty, try to disassemble the mother board and assemble it back. Note down each connectors you are removing if you are not expert. If you have isopropyl alcohol, clean the memory slots, watch if the clips are not broken. If nothing resolves, it will be the motherboard issue
Mar 02, 2010 | Dell Dimension 4700 PC Desktop
Orange light, no start
Well it could be the power supply, but, first try removing all the cards on the motherboard except the video card (remove and reseat that) assuming the video is no built in. Then turn it on. See what happens. Post back with results
Apr 04, 2009 | HP Pavilion 520w PC Desktop
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8400, no post. B and D amber.
GYGY diagnostic lights -- Memory is detected, but a memory configuration or compatibility error exists, and the 1-3-2 beep sound indicates the MEMORY test failed, which means one of the four memory has gone bad or the one of the four slots on the motherboard has gone bad, Neither the memory nor the mother board has completely gone bad, but either one slot or one memory has gone bad, try placing one memory on all slots and check which slot is the issue, then trying placing any 3 memory on the remainig slot to isolate the memory, then after that use the best 3 in the best 3 slots and check, you computer should work fine, this would help you for sure
Feb 06, 2009 | Dell Dimension 8400 PC Desktop
Green Light / Dead Tomtom - Please help with component id
that diode is a reverse polarity protection diode. An 1N414 will do ( available for very very little from almost ALL electronic component suppliers.) If there is NOTHING ELSE WRONG then the tomtom will still work without this diode. Its not needed in normal operation anyway. All it does is cause the fuse to blow in the cigarette lighter plug if the polarity is accidently reversed. Therefore , with a correct supply , it does nothing !
Aug 18, 2008 | Tomtom GO 300 GPS Receiver
ASUS p4s533 will not start
Your motherboard is bad and will need to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 08, 2008 | ASUS P4S533 Motherboard
Dell Dimension 8400 PC Desktop Logo
2,362 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
