Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
I have a Kenmore Elite Model 106.57863801 side by side stainless steel fridge. The doors squeak when opening and closing. How can I remedy this?
    President:
  • 1,218 Answers
Good day,
Spraying a good lubricant on the hinge pins should solve your problem. Sprays like WD-40 shouldn't be used because they may come in contact with your food.
I suggest you call around to your local appliance parts houses to see which one's carry a "food compatable" spray.
It's safe to use around food and can be saved for future use. Most service techs I know carry it with them in the service truck to use when needed.
Posted on Oct 05, 2010
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
Bottom of door makes loud squeaking on opening. I can't figure out how to lubricate. I'm wondering if removing the plastic molding on the bottom inside of the door would allow me access.
Yes by removing the inner door liner from the outer door panel you should be able to gain access to the door hinges,between the part of the hinge on the door and the hinge part on the tub is a plastic bushing that probably worn causing that sqeeking noise.
GENE
Oct 15, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore dishwasher elite door opens too fast, broken spring?
Could be that, the spring may have unhooked or it could be a defective damper connected to the door. Remove the side panels and check the operation of the door mechanism. (This will probably require the removal of the rear panel to gain access to the necessary fastners).
Jan 21, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
GE (Side x DSide) Adora: closing fridge door causes the freezer door to open
That will happen if you close the door too quickly or make sure the freezer door gasket is sealing properly.
Nov 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Kenmore elite freezer/fridge hot to the touch on the front.
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Jun 25, 2009 | Kenmore 63893 Stainless Steel Top Freezer...
White to stainless
Black, white and bisque seem to be the only colors available for the double convection oven. Might be possible to find the cooktop, but it's hard to know for sure without the model number.
In my experience, it's often not economical to switch to stainless steel as stainless steel panels can be extremely expensive (I've seen a freezer door on a side by side fridge sell for over $850... Just the freezer door!)
Mar 05, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
256 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
