Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Model 917.272650 what is the feller guage gap between oil & flywheel and below carberator there a wire plugs in the bottom what does that do,above that between float there a little set screw is there any adjustment on that screw
    Scholar:
  • 150 Answers
I usually use a business card to set the gap between Ign and flywheel. The rest of this posting is to vague to help you, sorry.
Posted on Oct 05, 2010
Air gap setting for 4 stroke rover mower model no 30694
I cant seem to get your model number to work for me but under Rover push mowers it looks like they use Briggs and Stratton engines so if true Air Gap: 0.203/0.305 mm (0.008/0.012 in.)
The way I do it is fold a piece of printer paper one inch folds four thickness, wrap around flywheel, roll the flywheel around so the magnet is pulling the coil up tight to the flywheel,the four thickness of the printer paper is your air gap, then tighten the screws . Pull on the paper as you rotate the flywheel to remove it. Dont forget to check that the little wire is plugged in other wise it wont shut off. Replace the spark plug and spark plug boot/wire as well as the flywheel cover and it should start up.
Mar 16, 2016 | Garden
Bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Mar 15, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
The saw wont start up
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Make sure there is fresh fuel mix in the tank and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Remove the spark plug and check for blue, snappy spark (plug gapped 0.020"). If weak or none, try a fresh plug. If no help, remove the left side cover to expose the flywheel and ignition module. Remove the ignition switch wire from the module coil and try for spark again. If still nothing, try setting the module pole gap by turning the flywheel magnets under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps don't close up at any point. Recheck for spark--if still nothing, replace the module using the above procedure. Assuming that the engine has good compression and the carburetor in not in trouble, it should start. Hope this helps!
Nov 08, 2010 | Husqvarna Chain Saw Handle Models 362 365...
How to install a ARMATURE-MAGNETO on a BRIGGS &STRATTON 18 H. ENGINE? Is there a certain gap between the fly wheel and the armature-magneto?
removw chop screen and blower housing unplug little wire under mag remove 2 screws and remove mag reverse prosess with new mag but pull mag away from fly wheel and snug screws center magnet on flywheel over legs of magneto place .010 feelre guage inbetween and loosen screws, hold mag against flywheel and tighten remove feeler guage reinstall kill wire on bottom of mag install blower housing and chop screen hope tis helps
Aug 07, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Timing adjustment for Poulan 18'' Wild Thing P4018WT
Ignition timing is fixed by use of a flywheel 'key' that locks the flywheel to the crankshaft. If the key happens to shear, then the timing will be incorrect. Expose the flywheel and check the ignition module gap to the flywheel magnets by using a thin business card for a gauge. Turn the magnets under the module, insert the card, and loosen the module mounting screws. Allow the module to stick to the magnets, then tighten the screws. Rotate the flywheel to remove the card, then turn it one complete revolution to make sure the gap doesn't close up any further. Remove the spark plug and check for snappy, blue spark when the engine is pulled through. If no spark, remove the ignition switch wire from the ignition module, the retry for spark. If still nothing, replace the ignition module itself. If pulling the wire gives spark, then check the ignition switch and the wire for grounding at some point. Hope this helps!
Jun 15, 2010 | Garden
No spark
You will need to remove the recoil cover, flywheel, and the cover over the points and condensor. Buy a new set of points and condensor and install them. Turn the engine over until it opens the points up and set them at .020 in. with a feeler guage. Re-assemble and make sure you tighten the flywheel tight enough or it will shear off the flywheel key. Also, before removing the flywheel check the gap between the magnet on the flywheel and the coil that the plug wire comes from. Also, make sure nothing is grounded out. (wire from points to coil).
Good luck,
Bart
Jun 11, 2009 | Air Tools & Compressors
Chipper won't start
what engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
May 11, 2009 | Heavy Machinery
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
57 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
