Question about Sharp Office Equipment & Supplies
Occassionally I get a blinking F5 and E7 error when powered up and the unit will not copy
  • Avondale Fleming
    Avondale Fleming May 11, 2010
    What model are you using?
F5 and e7 errors will occur on a sharp machine mainly due to dust on the optics. however, it will be easier for you to get better help if you give the model no. of the macine and the sub code for the error which you get by pressing the copy/start button while the error is displayed.
Posted on May 30, 2008
Hi plz check any paper jam in side the machine
Posted on May 29, 2008
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Jan 07, 2015 | Office Equipment & Supplies
How to clear F5 error in Sharp AR-5316E, my technician have already cleaned the glass and all the optics in the scanner including the lamp and the white strips on bottom but still the error remains.
F5 errorContent Copy lamp error
Detail Copy lamp voltage detection error
Cause Power unit trouble, Copy lamp trouble
Inverter trouble, MCU PWB trouble
Check and remedy
Replace the power unit.Check the copy lamp ON with SIM
5-3.
Replace the copy lamp.
Replace the inverter.
Replace the MCU PWB.
Aug 31, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have a F5 E7 error code door keeps locking
F5-E7 Code - Self clean latch will not unlock
Check this procedure to solve it:
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to
step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to
step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes
Hope this helps.
Oct 07, 2011 | KitchenAid KESC308LSS Electric Kitchen...
I have problem in Sharp AR-M205,and i don't know how to fix, error code F5
F5 00 Content Copy lamp lighting error Detail Copy lamp does not light despite the output of lighting signal. Copy lamp lights without the output of lighting signal. Cause DC power supply defective Control PWB defective Copy lamp defective Improper connection of harness between PCU PWB, DC power supply unit and copy lamp unit Check and remedy Check copy lamp for lighting with SIM5-3. Check harnesses and connectors between PCU PWB, DC power supply and copy lamp unit
Jan 12, 2010 | Sharp AR-M205 Copier
Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
Note: Applies to all F5-E... codes.
Sep 17, 2009 | Ovens
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
Jun 13, 2008 | Sharp AL 1631 Copier
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
