Question about HP LaserJet 4350 Printer
I have a 1/8" white (no ink) vertical streak on my output pages of my 4350 laserjet
    Scholar:
  • 107 Answers
Hello, well simple thing would be to check toner cartridge, change it. the next would be to see of the seal was pulled from toner cartridge, if problem persists with new toner, then problem may be something in the scanner unit of printer.
Posted on Oct 05, 2010
Pale copies and two vertical white streaks
I'm afraid that regarding pale copies, you are better off checking your consumables (toner, fusers, etc) and then try talking to Toshiba. However, the vertical white streaks can be caused by excess ink and other contaminants on the inside of the printer. If you open the main door to both the printer and finisher (if fitted) and look at all of the visible runners, feeders and other handling devices, try to see if any of them line up with your vertical streaks on a page. If so, try manually rolling them and cleaning them thoroughly. This might help remove some of the streaking (it did on mine).
Hope this helps, Alistair
Feb 28, 2011 | Toshiba e-Studio162D Copier
Hp 4250 laser jet vertical streak ghost image
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 04, 2010 | HP LaserJet 4250 Printer
Hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Mar 30, 2010 | HP LaserJet 1012 Printer
Streaks on my laserjet 3800
Hello sir; Remove the transfer belt unit, at the end of the unit you sill find cleaning unit, vaccunm it up, if neccesary, replace cleaning blade .
Oct 21, 2009 | HP LaserJet 3800 Printer
'Copy' output has vertical streak, 'Print' output is clean.
You likely have a smudge on the glass where the scanner reads the paper as it passes through the auto-feeder. On a flatbed - this is not the large rectangle of glass. This is a thin sliver of glass to the side.
Often a drop of White-out will do this.
Aug 27, 2009 | HP LaserJet 2840 Printer
There is a white vertical streak on pages I print.
You can pull out each cartridge and shake it gently to redistribute the toner. Try a half page test to eliminate the various stages of the image formation. The timing on this is not easy but through trial and error it can be helpful.
Jun 25, 2009 | Cannon MULTIPASS C530 Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
2 IN. GRAY AREA DOWN SIDE PAPER
There are several things that can cause this. A worn toner cartridge and/or transfer roller can cause vertical smears, but it may also be a worn fuser assembly. The teflon coating on the fixing (heat) roller wears off, and leaves vertical streaks of varying widths on the pages. Sometimes you may see "ghost" images on the pages for the same reason. Open the back door of the printer, and hold down the exit guide on the fuser (carefull, it may be very hot). There are two long rollers, the lower one is black, the upper roller is either grey or shiny brown. That's the teflon coating. See if it's peeled or damaged. If so, replace the fuser assembly.
Feb 10, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4350 Printer Logo
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
