Question about Samsung 19" LCD Syncmaster 931BW Monitor
My Samsung SyncMaster 931BW monitor has been working fine for me. It was working fine last night turn it back on this morning and the screen is just black. Reset computer checked the cords and power outlet none of which seem to help. The blue power light still flashes and you can turn it on or off but nothing on the screen changes, there's some occasional noise but no real activity I haven't noticed the screen at any point show even flashes of my screen.
  • dbm365 Oct 05, 2010
    After about an hour of leaving it on the monitor started working. I'd like not to go through this everyday so if there are any fixes I'd love to hear about them.
  • 11,361 Answers
Try it with another PC to make sure is is not the PC video card problem, also chek the cable. If it still does not work, then you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 05, 2010
Samsung 19 "LCD SyncMaster 931BW ...Colored
Hook a spare monitor to the computer to insure there is no problem, if everything checks out okay,the problem is in the Samsung screen display and is not cost effective to repair, far cheaper to buy new. But if both screens show the same problem, it is a video graphics card issue in the computer, one further thing if the video cord is detachable from both ends, sub another cord.
Feb 04, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
When I turn off monitor at night and turn back on in the morning I get a white screen only. After turning on and off several times and a long wait my desktop will display. What causes this problem and how...
check if your LCD monitor have bloated caps
check this site for what bloated caps look like.
http://pcmediks.blogspot.com/2010/09/samsung-syncmaster-540n-with-power-but.html
Nov 10, 2010 | KDS K22mdwb LCD Monitor
A few seconds after i turn my syncmaster 931bw on the screen goes black but if a shine a torch close up to the screen i can see the icons does this mean the bulbs need replacing?
r_mackie923, If screen display was crisp and bright 1 to 2 weeks ago, you should only need to replace the inverter board or troubleshoot down to component level to restore it to normal use. Just follow links you find in the fixya profiles of "budmrtn", "buddymc" and "louie12fix" and other LCD cold-cathode-fluorescent-lamp monitor technicians here on fixya to determine if you will DIY or contract out the work!! Also view some DIY video clips at YOUTUBE to help with your decision. 12fixlouie
May 18, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor was working fine last night but I think Microsoft did an update last night and i can't get the monitor to display. I get a check signal cable box that floats across the screen.Also do not have the...
Please unplug the monitor cable from the back panle of the cpu and replug it back again ensuring a tight connection.
this should take care of the problem.
Jan 22, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Screen on first start doesn't work
I have a SyncMaster 931BW which I duel Screen with a analogue montior.
There are Three things that I would check:
  1. Connection: if you are using the DVI adaptor, try using just the analogue (VGA) connection into your PC. You may have a faulty DVI adaptor which the PC cannot detect an output device.
  2. Drivers: If you have a standard monitor connect that to the PC and see if there is any output, if so, you may need to install the drivers for your monitor. You should have a Samsung Drivers Disc, or visit the Samsung website: http://www.samsung.com/uk/support/download/supportDown.do?model_nm=930BF&mType=DR&vType=L
  3. Cable: ensure that the cables are not knotted, and that within the adaptors the pins are all there and not bent as there is not a proper connection with the device.
Try them.
Jan 01, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Samsung 19" LCD Syncmaster 931BW Monitor Logo
1,103 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
