Question about Hoshizaki KM-630M Crescent Cuber Ice Maker
Just replace the bin switch on a hoshizaki 630mab still does nada likes it dead in the water has power going to it.
  • Hoshizaki Master
  • 1,253 Answers
According to my wiring diagram, the power goes thru the bin switch and then goes to terminal #10 on the control board, #7 on the control board, and branches off and goes thru the control switch and high pressure switch and then to the transformer.
I would check the "Ice/Wash" switch to be sure it is allowing power thru it. See if you have power at the high pressure switch. If you do, control switch is probably good so that would send me to the transformer. See if primary and secondary power is present.
Let me know if I can be of further help
Posted on Oct 12, 2010
I have a hoshizaki ice maker c 100bae ad and it makes great ice but then the ice melts and water collects at the bottom of the bin and doesn't drain. Any ideas as to what's going on? Thanks Denise
Drain is probably plugged. Get some compressed air like a portable air compressor to blow the line out. Or you could take the line apart and clean it.
Oct 28, 2016 | Hoshizaki Refrigerators
Hoshizaki KM-630MAB
Check your refrigerant pressures during harvest. The board is picking up a fault. You could have a thermister problem on the suction line.
Jun 26, 2014 | Hoshizaki Kitchen Appliances - Others
Hoshizaki km-650 mah keep dumping water nothing at all running.
really sounds like the board needs replacing. after 1 minute, if the float is doing it's job, the compressor is to come on provided the water level is correct and the float is doing what it was designed to do.
Nov 30, 2012 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
I STARTED A HOSHIZAKI TOOK TAPE OFF CURTAIN LOWERED BIN CONTROL INTO BIN CONNECTED BIN CONTROL HARDNESS UNIT WORKED GOOD BUT NOW WATER IS LEAKING INTO BIN MELTING ICE IN BIN ANY IDEA OF WHAT COULD BE...
Start by looking for water valve leaking. Turn machine off and if water is entering machine, water valve is not seating. Let me know if you need more than this.
Feb 14, 2011 | Hoshizaki KM-1300S 3-Phase Stackable...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
KM-500MAH won't go into harvest mode
The float switch controls the harvest cycle.
Apr 22, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-1600S too much water supply
If water is standing in the bin the drain is clogged. If water is raining down into the bin, Machine may not be level or the drain on the ice machine maybe partially clogged. If machine freezes up water will rain into bin too. Water fills ice machine while in harvest and continues to fill until ice machine`s suction reaches 49 degrees and the defrost timer times out.(usually 1-3 minutes after suction line reaches 49 degrees)
Jan 16, 2009 | Hoshizaki KM-1600S Stackable Crescent...
Hoshizaki KM-630M Crescent Cuber Ice Maker Logo
207 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
