Question about Sony Ericsson W910i Cellular Phone
I have a problem in my phone, the problem is that when on the phone off again on again off until the batery low, please if anyone knows please help me
Lg gd850 low battery when powering up the phone
Please try fully charging it. If it still won't work, it's time for a new battery.
Sep 03, 2012 | LG Cell Phones
MY MOB NOKIA E71 TURN OF ,THE BATERY IS FULL BUT TURN OF SOMETIMES..I DONT KNOW WHY? IT NEEDS FOR RESTORE FACTORY SETTINGS? PLEASE HELP ME.
hi ,
one of the reason there is the battey is loosen up in the battery connector..try to tighten the battey using a thick object ...if you do that thing and the problem is still there ,removed your battery again with your memory card...then insert your battery and turn it on ,observe the phone if it will be turn off again ,if not your memory card is having a virus and need to reformat ...and your phone will need to format also by doing this ..go to MENU > SETTING >RESTORE FACTORY SETTING .it will ask for security code ,( if not change the default code is 12345) enter it ..the phone will reboot ,wait until it done...
now ,you can test the phone again ..if you do all the action below and the phone is still turning off ,better go to a nokia care center near you to fix your problem..
i hope it will help you ,thanks for trusting fixya..
Feb 07, 2011 | Nokia E71 Smartphone
I have a 93 accord with the d4 blinking. i checked the solenoids and that wasnt the problem. i have to shift the gears my self and its an automatic. my batery was really low and thats when i noticed...
I am seeing this problem a lot on this board. I had same problem. Change the TCU unit under the passenger side floor board (pull up carpet and you will see it, easy to change). Got a used one from a junk yard--lot cheaper.
Mar 13, 2017 | 1993 Honda Accord
Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
Oct 13, 2009 | Canon PowerShot A720 IS Digital Camera
My n73 hang i cant use my phone if i replace batery hang again
Formating may solve this.
*You will lost contacts and files on phone, if you do this*
turn off the phone, press 3,*,call(green one) at a time and power on holding the keys ( it means finally 4 keys at a time, dnt laugh , it is way, phone can he hard formatted)
Try untill it askes for the time and country. Pressing 4 keys at a time is a bit tricky so, it is easy to miss one/two attempts, atleast i do.
Oct 09, 2009 | Nokia N73 Cellular Phone
Help
I don't know what program you were using to upgrade, but it seems that you did not have enough charge on your battery. Try to charge you batery fully with another phone or get a hold of any other V3 phone and use their batery. Then press the * & # together and press the on/off button. it should take you to the boot loader mode. At this time the computer and updater proram should recognize your phone. But I do not know what program you are using.
Mar 10, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Problems with phone
it seems like that.but it can be solved.go to the samsung care & ask to restore the phone and update its software.
Dec 24, 2008 | Samsung SGH-J600 Cellular Phone
I NEED HELP WITH MY I880
i got the same f problem
but i change the baterie and guees what! the new baterie dont take the charge, something wrong with the phone,
Apr 28, 2008 | Motorola Mobility i880 Cellular Phone
L7 water damage
I dropped my phone in the toilet when it fell out of my back pocket. The best thing to do is dry it as well as possible and then leave it out to dry. I let my phone dry for approximately 2-4 weeks and now it's working again. I found this out after I went out and bought another phone. LRL from Texas.
Nov 17, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Sony Ericsson W910i Cellular Phone Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
