Question about Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME
I purchased and installed a Tuscany Brass "Siena" Single handle tub & shower faucet model 900 50524CP. When the faucet is turned on, water also comes out from the shower head. Also, the water is luke warm. When reading the manual to find out how to adjust, the directions and illustrations do not resemble this particular model at all.
2 Suggested Answers
SOURCE: I have installed a Tuscany
I have the same problem. Have you heard a solution?
Posted on May 02, 2011
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    My bathroom faucet drips. How do I repair?
    there is a seal in the valve assembly that is warn they usually dell kits for it from a hardware or home depot store
    Sep 11, 2014 | Plumbing
    New shower valve installed but can only get cold water seems to be an issue with a small cartridge inside the control
    I have been searching the Internet for solutions to my problem which is that I get no hot water from my LDR Tuscany Brass Anti-scald, Pressure Balance Single Handle Tub and Shower Valve. I've determined that my manual does not match my valve exactly but I've been able to extract the cartridge and look at the insides. This valve was never in active use since installation so there was no mineral build-up. But a couple of years ago, our city mistakenly turned off our water shut-off valve in the street while trying to find a leak. Rust and particulates came rushing through our water supply pipes and contaminated almost every faucet we have so I think something might have happened to this valve at that time. Does anyone know if those screws on each side of the center of the valve are truly just "stop valves" and might be clogged up throwing off the balancing mechanism?
    Nov 19, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
    I just installed a single handle tub & shower faucet, when I checked for water flow there was barely a dribble. I suspect there is blockage in the valve. I would like to take out the valve unit, to...
    If you soldered the faucet without removing the cartrige you may have damaged it. they have to be removed before soldering. if not, too much solder while soldering may plug port.
    Sep 10, 2010 | Peerless Industries Peerless& Single...
    No cold water
    Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
    Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
    Looking for cartridge for Tuscany Brass Tub Faucet Single Handle appears to be Ceramic Disk Type
    While there are several cartridges that look similiar to what you have posted, Danco it self is an aftermarket parts replacement business. From my point of observation, your posted pic is of a Delta stem which visually has some distinctive attributes. Most every thing Danco makes is a copy or OEM replacement part packaged under their name.
    Mar 16, 2010 | Danco Faucet Cartridge
    The moen began to leak over time now i cant turn the water for
    Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
    Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
    Delta T13090 faucet shower head working at the same time.
    The only possible explaination is that the water is finding it easier to go up than down. Water is lazy, just like me. ;)
    Use an allen key to remove the tub spout. It's underneath and awkward. Once the allen key is loose, the spout just slides off. Try running the water. This may solve your problem and all you'll need is a new tub spout. If not.....
    Turn the water off to the house.
    Use an allen key to remove the handle.
    Use a phillips to remove the trim plate (2 screws). Cut the silicone around the trim if it's there (which, in a proper installation it shouldn't be, but...)
    Unscrew the nut (usually chrome) holding the cartridge into the brass body of the valve. The cartridge pulls straight out. Check for restriction in the ports of the cartridge itself. Check for restriction in the line going down to the tub spout. If you can't find anything, replace the cartridge.
    Reassemble & Enjoy!
    Aug 05, 2009 | Delta & Single Handle Shower Faucet
    Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME Logo
    685 people viewed this question
    Top Ldr Industries Home Experts
    Donni Steen
    Tom Chichester
    Are you a Ldr Industries Home Expert? Answer questions, earn points and help others
