Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
What round file size do I use to sharpen my saw??
  • 333 Answers
What is the Ryobi expand-it chainsaw chain sharpening angle for the 10 inch blade?
This is what I did. I took my saw to a lawn and garden store that sells chainsaws. I purchased a file and a file guide made for my size chain. It is easy. Just a few strokes with the round file on the teeth and a few strokes on the rackers and it is good to go.
Mar 12, 2016 | Ryobi Garden
Best way to sharpen ms 250 c stihl chain
I can't show you pictures but I can try to explain. Tighten the chain on the saw to the normal working tension. If possible put your saw in a vice with the vice jaws clamped on the bar in a way that allows free movement of the chain around the bar when the chain brake is off. work your way around the chain to find the shortest tooth on the chain. Sharpen that tooth by using a file (4.8mm for the normal chain on that saw). You should work at 30 degrees across the face of the tooth.The spec says you should also angle the sharpening at 5 degrees from horizontal but if you have the chain at normal tension then the movement of the chain in the bar while sharpening is likely to give you about 5 degrees anyway - so just work horizontally and you won't have a problem. You only need gentle pressure pressing back towards the engine of the saw and enough strokes to get the surface of the tooth free of any pits, chips and rounded edges. When finished mark that tooth - I use a felt pen so it is easy to see. Do the same for every other tooth but to ensure the saw cuts straight (and does not give you curved cuts) it is essential that every tooth is sharpened to the same size as the shortest (use a measuring gauge if necessary). When you have been all the way round on all teeth then you need to adjust the depth gauges on the chain links. If you don't then the saw will probably only produce fine dust and not nice cut wood chips. With a flat file and depth gauge tool place the tool along the teeth pulled back against one. Through the gauge fingers you will see the chain depth limiter and this needs to be filed down to the level of the gauge tool. If you start the process at the tooth you marked earlier you will easily see when you have worked all the way around. Your chain should now be sharp. Before using it it is advisable to remove the chain from the saw and clean any filings out of the chain and bar to avoid them causing unnecessary wear. Good luck.
Sep 11, 2014 | Stihl Garden
Chain file sharpening size
For the normal size chain you use a 5.2mm round file. Smaller chains for top handles take a 4mm round file.
Jan 02, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Size file sharpen poulan 18
Take your saw to a shop that repairs chainsaws. They will be able to get you the right file for the size of chain on your saw.
Dec 18, 2013 | Echo CS600P Gas Chainsaw 20 Inch
Engine starts, runs, chain goes around, but cuts very weak, leaving black marks on the wood from rubbing but not cutting
You have a dull chain. Check out the video below to learn how to hand sharpen the chain:
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
Apr 18, 2011 | Husqvarna Garden
Sharpening Ryobi 4046c - what size file ?
Chain Type File File Profile
1/4” Micro 5/32” (4.0 mm) Round
3/8” Picco Mini 5/32” (4.0 mm) Round
3/8” Picco Micro 5/32” (4.0 mm) Round
.325” Micro, Super 3/16” (4.8 mm) Round
3/8” Micro, Super 13/64” (5.2 mm) Round
3/8” Square Grnd Tapered
.404” Micro, Super 7/32” (5.5 mm) Round
.404” Square Grnd Tapered
Depth Gauge File Flat
Jul 11, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
279 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
