Question about Car Audio & Video
Im having major problems that even my mechanics cant figure out. My car will turn on fine, but once I drive it around for like 5 or so min over 30 it slowy comes to a complete stop. The battery light will come on. The battery got cleaned and is fully charging. And the alternator is new. My mechanic checked out the wiring and nothing seemed loose. It's a 99 mercury cougar
    President:
  • 1,768 Answers
1. check the ground cable to the battery and the chassis.
2.Check the alternator again for a possible weak diode array.
3. check the computer to see if it is giving proper voltage for system check for the
battery check.
this may take a mechanic to check this.
4. If battery is over 4 year old it may need to be replaced ( dead cell in battery or weak)
will not hold charge. If battery is a sealed battery this may be the cause.
5. check all grounds to the fuse box to see if you have proper ground potential that is
you will need to have ohm readings that do not fluctuate.
6. If you have installed any components such as new cds,dvd units, speakers, tachometer
check for proper ground seating.
Posted on Oct 05, 2010
My headlights only turn on when they want. They are brand new as of late last year. PLEASE HELP!
These cars were designed to have daytime running lights, that can turn off with the ebrake being pulled, so perhaps whatever wiring mechanism that enable that, is failing.
Mar 21, 2017 | 1999 Oldsmobile Aurora
I have a 1998 mitsubishi montero sprot 2Wd 2.4L 5 speed. i need to know what is the transmission oil pan gasket called and i also need to know what transmission fluid does it take? i have replaced the...
take the pan off clean both surfaces the tranny and the pan put an 1/8th " bead around the pan making put the bolts in the holes let dry for 20 to 30 min then put it together evenly torque the pan down from side to side and im sure the autoparts knows the correct fluid and how much
Sep 02, 2017 | Mitsubishi Montero Sport Cars & Trucks
After i've been driving for about 30-60 mins. and
Idle air controll motor is bad, 60 dollar part and 5 mins to change
Jun 12, 2010 | 1996 Ford Explorer
Starts but dont like to drive
Catalytic convert or is plugged. Disconnect exhaust in front of Cat. and see what happens.
Jan 20, 2010 | 1993 GMC Sierra K1500
Rover 100 Metro Starting Problem
if you can drive it for 5 mins,turn it off and restart it than your alternator is doing its job so your battery probably has a bad cell and getting a new battery should fix your problem
Jan 07, 2009 | 1992 Geo Metro
Intermedete power lose
I had the same problem, I changed the fuel filter, put a new ignition in the column, a new module in the distributor and a new crank module, it turned out to be the fuel pump itself, go figure.
Dec 12, 2008 | 1995 Jeep Grand Cherokee
Computer won't start up!
Waiting for 10 or 15 or even 30 minutes doesn't make much sense to me. What kind of flash drive or drives do you use? .. USB Thumb/Pen/Flash drive? .. If your flash drives in "My Computer" folder just happen to disappear, does the computer still working or freezed state? When you say your computer does not want to start on AT ALL.' the machine is not running at all or just that the operating system is not booting up?
Sep 18, 2007 | Medion M3 Director 5100 PC Desktop
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
