Question about Dishwashers
High pitched squeal during the washing cycle - Dishwashers
It's a faulty design!
Posted on Nov 22, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Brand new LG LDF6920 makes a whistling/high pitch squealing noise even during 1st test run, no dishes no contaminants added. It is during the wash motor cycle once the wash pump gets up to speed *screech*....
I had a brand new Dishwasher do that, it wasn't an LG it was a Frigidaire i think, turned out to be some bits of plastic from the manufacturing process that were in the pump. I had another one that made thumping noises and turned out to be a little piece of the tape, you know all that blue or green tape they hold everything in place with when its new. Did you run it through a few cycles and see if the noise quit? Believe it or not when i called about the one that was squealing their customer service said to run a couple cycles to remove anything that might be in the pump from manufacturing, sure enough midway through the second wash cycle it just went quiet and never made another noise again after two years.
Jan 11, 2018 | LG Dishwashers
Our water softener makes a high pitched squealing noise every 10 min. or so, and then quits for several hours only to start again during the night when we're trying to sleep. Our water softener repairman...
A softener will generally make a high pitch squeal when it is backwashing. This is generally the first cycle in most softeners. It may also do this during the final fast rinse cycle. The second brining cycle takes about an hour. That is why you may have a delay in the squeal. Also I have seen at times when a power surge can force the drive motor into a short backwash. Usually just a few minutes. It may help to put a surge surpressor at the water softener plug.
RJ
Aug 22, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
High pitched sound during spin cycle
That machine doesn't have a belt. It is more likely that you have a bearing going bad. You may also have a tub seal starting to go which then leaks water onto the bearing, damaging it.
Mar 07, 2010 | Washing Machines
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Jul 15, 2009 | Maytag PAV2300 Top Load Washer
High pitched squeal
sounds like the water pump bearing might be defective. best advice is to replace the pump.
Jun 09, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
