Question about Dryers
Frigidaire Gas, Front Loading Dryer, GLG0332A54 Stand alone or can be used as top piece on top of washer. Purchased 2004. Need dimensions for: heighth, width, depth for the machine plus the extra space around it needed for hookups. The diagram which shows all these measurements would be great. And also for Frigidaire, front loading washing machine. GLTF530DS. Stand alone or can be used as bottom piece with dryer on top. Purchased 2004. Diagram would be very helpful. Same as above.
    President:
  • 1,554 Answers
GLTF530DS Specifications
GLGQ332AS Specifications
These models can be stacked together. The dryer needs the top panel with part number 131629100. Check the Installation Instructions for both machines for further information.
GLTF530DS Installation Instructions
GLGQ332AS Installation Instructions
Posted on Oct 05, 2010
Tip
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
How to open front panel
There were two (2) small screws at the very bottom of the front.
  • Remove them securing the dryer front access panel to the dryer cabinet.
  • Lift the panel until the tabs can be disengaged from the cabinet.
  • Remove the panel and set aside.
Installation Manual (see page 8)
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131661700p1-8.pdf
Owner's Guide
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131781700ceen.pdf
Operating Instructions
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131919500e.pdf
Cutout Dimensions
http://www.frigidaire.com/products/images/documents/cutout_dimensions/lc.pdf
Energy Guide
http://www.frigidaire.com/products/images/documents/energy_guides/134089300-USA.pdf
Feb 18, 2014 | Frigidaire GLET1031 Top Load Stacked...
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
Oct 18, 2013 | Frigidaire FEQ332E Electric Dryer
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
What kind of plastic is the "window" in a frigidaire front loading washer made of? Recently when my husband pulled on the semi circular plastic piece, which is part of the "window", it split, almost c
Hello Ann Calk -Unfortunately depending on which part it is exactly since there is any adhesive available to glue it back together you need to purchase the entire door panel. I would suggest contacting a professional to accurately diagnose and repair the window washer.
Sep 30, 2012 | Frigidaire FTF2140FS Front Load Washer /...
How do I change my dryer belt on 1994 MAYTAG dryer?
Assuming this is stand alone front loading dryer, to replace the belt, you access the drum from both the back service access panel and the top. Pop the top at the front corners and it will hinge up at the back.
Reply back with the make and model number of your specific dryer and I can help you more.
Dec 17, 2009 | Cars & Trucks
I purchased the Frigidaire stackable front loading washer/dryer pair in 2004. A friend also has the same model and so did my sister. My sister said there was a loud clunk one day and the washer stopped...
Your power supply has failed, need part # 134409904, check ebay, about $70
this board is in a white plastic box with wires running to the motor, access from the back of the machine, maybe say magnetek on it 4246-99-1
Jan 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
