Question about AT&T Blackberry Curve 8300 Smartphone
Address book How do I add a new entry to my existing address book?
  • Henspark Jun 02, 2008
    Dear Ogre
    Fabulous! Clear and efficient. Great service.
    Henspark
Select the Address Book application from the main screen (with all the icons.) The address book icon is black and white in the default theme.
Press the "Menu" button (just left of the trackball)
Scroll up or down to "New Address" and push the trackball in (select the menu item.)
Fill in all the details that you have for the contact.
Press the "Menu" button again (left of the trackball)
Scroll up or down to "Save" and select it by pushing the trackball in.
Bob's your uncle!
Posted on May 28, 2008
I need to know how to delete addresses that I do not need anymore on my Magellan RoadMate 1440
Here is a video that explains hoe to add, edit, AND DELETE address book entries in a Magellan Roadmate. The delete process is in the last minute or so if you don't want to view the entire process.
How do add edit and delete address book entries Video Demonstration
Oct 27, 2016 | Magellan GPS
How do I add more than one phone number and email address to existing contacts on my Samsung Galaxy J1 mini?
there is something in it called edit under options . or try writing down the name number(s) you want then delete the first entry and then add NEW CONTACT
Jun 24, 2016 | Samsung Cell Phones
I have a XEROX WorkCentre 5638. How do export the existing address book to add addition email address to it?
This model does not support exporting of the address book. However editing of the address book is very easily accomplished by following the steps below.
We encourage you to use our knowledgebase http://mrc360.com/XeroxKnowledgeBase
These instructions link is here: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=477,E=0000000000016114582,K=3962,Sxi=6,Case=obj(23672)
Solution : Add or Remove Addresses From the Public Address Book Using CentreWare Internet Services (CWIS) To add addresses:
  1. Open an Internet browser window on the desktop.
  2. Enter the IP address for the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services (CWIS) window will be displayed.
  3. Click on the [Address Book] tab.
    NOTE: If prompted, enter the username and password in the fields provided, and then click on [OK]. The default username is "admin" and the password is "1111".
  4. Select [Add New Entry].
  5. Enter the friendly name and the e-mail address for the new entry.
  6. Click on [Save & New] or [Save & Close].
  7. Click on the [Logout] link and logout of CWIS.
  8. Close the browser window.
To remove addresses:
    NOTE: If necessary, enter the username and password in the fields provided, and then click on [OK]. The default username is "admin" and the password is "1111".
  4. Click on [View All Names].
  5. Click on [Delete] next to the name you want to remove.
  6. Click [OK] to delete.
MRC
Jan 12, 2015 | Xerox Office Equipment & Supplies
How do I put ina new contact
If you are using outlook simply right click on the senders name, scroll down and you should see add to contacts. Click on that and it will open a window which will allow you to write in all the relevant details. Once that is done click save and exit.
Another option is to open your address book, click on file (top left corner) and find "New Entry" . Click on new entry and add the relevant details,save and exit.
May 10, 2014 | Computers & Internet
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
Is there any way to make the persons name appear for a text
It should be as simple as adding their name and number to the address book on the phone.
Make sure to list the number under the Mobile Phone line.
While in the address book, there is usually a line that says "New Entry" or "Add number" etc...(without the type of phone I cant get specific).
Another method is to into the text message itself and do an options click (again without the phone cant be specific) and there should be an option to add the number to the address book.
Aug 05, 2009 | Cell Phones
Add a new email address
if you are connected thru the network the best way is to start Top access then click registration tab,then address book. on that page you will find add address.
or on the machine press "user functions",then tab address,then press address book,find free slot, press entry. there u will find space everything. after U enter just confirm that and that it.
Jul 14, 2009 | Toshiba E-STUDIO 450 Copier
Im trying to find out how to update my address book in my copycenter c128
You can manually enter addresses by going to Machine Status> Tools. Add Address Book Entry and entering single entries there. Youcan also upload a .csv by browsing into the copier via the IP and going to Proprties> Services> Internet Messaging> E-mail> Public Address Book and Mapping the existing address book to your computer. It will be in a Comma Seperated Value format that can be Modified in Excel and reuploaded in the same area, but instead of mapping existing address book, Upload .CSV file to Address Book and exiting.
Mar 05, 2009 | Xerox CopyCentre C128 Black and White...
I ve lost my adress book
if you address book is on exchange server you can recover from it: create a new outlook profile using same credentials.
Jan 12, 2009 | Computers & Internet
Canon ImageRunner 3045 -- One Touch Feature
have you done this at the machine control panel or by browsing to the web interface? You may be able to do it there. If not you are SOL.
Jul 07, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
AT&T Blackberry Curve 8300 Smartphone Logo
97 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
