Question about Toshiba 1360 Black and White Copier
I have a problem with photocopier toshiba 1560 can not print copies even i put new toner cartridge I, ve seen inside the small motor which should discharge the tonner powder did not turn the weel to download the new tonner ...so no copies....what should i do, please !???
  • didi2005 Oct 09, 2010
    Did u fix the toner wrongly?
    If toner problem, the m/c should prompt toner low message...
Devloper istallation code for Toshiba 1560 photocopier machine
Posted on Nov 21, 2010
How can I solve Toshiba e studio 257 photocopier toner problem?
Try turning the main power switch off or disconnect the power, wait 20 seconds then turn back on again. This should reset the toner.
Aug 29, 2016 | Toshiba Office Equipment & Supplies
My Toshiba estudio 4511 says call service
Your CYAN is one of 3 colors the "Smart guys" came up with to make 252 some colors. Between Cyan Magenta Yellow and the ever so present Black you can make all your colors. Obviously you don't need the three C,M,Y to make a black and white copy. So the issue remains that a low or empty Cyan (pronounced S-eye-ann)
A couple differant issues I've run into since the creation of color copies near 2003 is A pull tab on the toner isn't pulled off before inserting the tube. Another is for several possible reasons the toner just isn't getting down into the developer mixing auger. There is also, upon occasion a situation that the motor that turns the toner auger inside the new toner cartridge doesn't turn enough/properly/ or at all. These days that will almost always throw a code in the display window. My 23years of Toshiba tells me try your C cartridge, play with it a bit and make sure its in right, with tab pulled. another tool is monitoring how long it tries to and the Cyan, does it attempt to restore it' levels for about 90 seconds or is it immediately tell you there's a cyan issue? Can you hear the motor and toner bottle turning? It should tell you "adding Cyan Toner" or even "Check Cyan Cartridge" worst case scenario you call Toshiba business Solutions and they vacuum it all out and do some adjustments......could be a good thing With Toshiba you get a lot of bang for your buck, meaning: a service call is good every once in a while. Your 4511 is a work horse you won't regret $pending for service. ~~~~~> SC
Sep 22, 2014 | Toshiba Estudio 4511 Color Printer,...
Toshiba E-Studio 232 PhotoCopy Too Light, Why?
one simple way that may help you out , take out toner cartridge shake it to equalize toner powder , try it may work
Jul 25, 2014 | Toshiba E-Studio 232 Copier, 232 Digital...
Toshiba 166 showing toner light after replacing new cartridge
do this first remove the toner from the machine second input the 08 695 0 then close the machine then put the toner back
May 17, 2012 | Office Equipment & Supplies
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
Xerox M15i uneven print and photocopy quality. Center of the page is darker than edges. I have run the clean drum, put in a new toner cartridge.
If the problem appears BOTH by copy and print situations, the problem is the drum unit itself.
Unfortunately you have to buy a new drum assy.
Sep 04, 2010 | Xerox Office Equipment & Supplies
Fix hp laserjet 5100
There is either something in the paper path (burned in probably) or the paper path is extremely dirty. The paper path can include the cartridge. I
ve seen this problem alot with rebuilt cartridges. I would turn off the printer (unplug) open all the doors, take out the cartridge and toner waste bottle(s). Now with a flashlite and a vacuum cleaner go after all the dirt you can find inside. If you do find caked toner on a roller, use rubbing alcohol to remove it. Once you're sure there is nothing in the paper path then reassemble and try the printing. If the same problem is there the cartridge is definately suspect. Good luck
Feb 25, 2010 | HP LaserJet 5100 Printer
New toner cartridge not working, Toshiba e-Studio232 Photocopier
Is the cart, a OEM or third party, Mite require only OEM, with the proper circuit board on board.
Aug 15, 2009 | Toshiba e-Studio 232 Black and White...
Photocopier not copying
MAY BE TONER IS NOT FEEDING OR CHANGE ITS DEVELOPER IT IS WEAK.MIAN AKHLAQ
Sep 30, 2008 | Office Equipment & Supplies
Toshiba 1360 Black and White Copier Logo
494 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
