Question about Cameras
WHEN POWER IS TURNED ON THE SCREEN SAYS 'ACCESS' THEN IT SWITCHES OFF.
  • 10,594 Answers
It can be due to low charged battery. replace with full charged battery and try again. Please mention model and make of your camera.
Posted on May 28, 2008
Have to know how to open joytab
Use a rubber same as to remove iphone screen. Lift screen out opposite end to all the side switches. When screen removed it gives access to power board.
Dec 04, 2012 | Tablets & eReaders
What part needs to be replaced when the monitor switches off after being turned on?
you must need to check first weather the cause is bad power inverter board for screen back light or a leak like bulged capacitors in the power supply board.
Oct 15, 2012 | HP W2338H Monitor
I have a Haier 12,000 BTU window air conditioner and the thing froze up when i turned it off by the power button the compressor still ran. I had to unplug the unit for it to stop. I thawed the unit plugged...
your wiring is melted or shorted under the electrical access panel where the selector switches are. You will usually see melted wires and burnt ends. Your compressr start wire has melted to a hot. good luck and remember to unplug the unit first
Aug 08, 2010 | Haier HWR12XC5 Air Conditioner
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
The power switch does not switch (no click)
Unplug the monitor from the power
Unplug the monitor from the computer
Plug the monitor back in.
Try turning it on.
DOES IT SAY "NO SOUCRE DETECTED" or soemthing like that???
if it DOESN'T it means there is something wrong with the computer.
if it DOES:
plug it back on to the computer, turn the computer power off.
Press and hold the power button on the computer for about 15 seconds.
Plug the computer back on.
Try turning the computer on.
if it's not turning on again there a problem either with your monitor cable, or the plug, or the video card plug. It is unlikely that your video card is broken if you hear no wired series of short and long beeps when you try turning the computer on.
Good luck.
Give us updates if you need more assistance
Aug 11, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Volume & Menu screen flipping out
Replace all of your contact switches on front panel board power/off/on vol- vol+ ch- ch+.
Jan 05, 2009 | RCA HD52W66 Projection Television
Frigidaire gas range - model plcf489ccc - the ignignitor continues to spark and click even when everything is turned off. We turned the power off for a while and when the power was turned back on it...
Mounted on each each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. On some models these switches are individually replaceable, others the switch is an assembly of all four.
Jun 22, 2008 | Frigidaire Kitchen Ranges
Philips dvp 3020 dvd player
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 22, 2008 | Philips DVP-3005 DVD Player
'Access' screen?
the (Access) in the screen refer to one of this problem, the lens mechanism is unable to start due to plastic broken parts in it or dust, or battery poor power, use a rechargeable battery over 1200 uAh of power
Jun 13, 2006 | Sony Cyber-shot DSC-S600 Digital Camera
Cameras Logo
109 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
