Question about Lexmark T642 Laser Printer
Hi my printer is not printing from 2nd drawer why do you think thats happening
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
This can be caused for a lot of resons.
1.Pickup rollers are worn
2.Paper is set to the wrong size (on the machine or in the driver)
3.Paper is set to the wrong type (on the machine or in the driver)
Posted on Oct 07, 2010
How do I clear the memory
I would think that the document is not on the printer, it's in the printer spool. Open the printer properties and clear the queue.
Mar 13, 2015 | Office Equipment & Supplies
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
Paper from Tray doesn't load.
put paper in the upper slot (known as the MP), pull all paper from lower tray, send document to print and see if it prints ok - if it does, the problem may be with the lower print drawer - there is a spring under metal pad that lifts paper so it's grabbed by the printer paper transport. the spring may have broken or become dislodged so separation pad (the metal plate holding paper up) remains down - the transport "thinks" there is no paper
Jul 08, 2010 | Brother MFC-8460N Laser Printer
It started getting jammed recently quite often and generally happens when the paper tray isn't full. It usually either gets jammed near the tray or in the back.
i take it that you getting mutiple different jams and pretty often correct? these printer use a paper size select pcb when these start to go bad the paper size can be change every time you close the drawer or every other page you print. print your network page and see if it prints as big as the page if its smaller the printer thinks it has smaller paper if the lower black line of the box around this page is missing it thinks it should have longer paper. this board is located behind the metel box the logic board is mounted in. for cheaper prices,instruction and support for your lexmark lasers go to L-tech4u.com write an email if you dont see what you need listed they will have it
Nov 12, 2009 | Lexmark Optra S 1855 Laser Printer
PAPER EDGE FOLDS OVER TOP LEFT WHEN COMING OUT OF THE PRINTER
the reason why i ask that because if the fold looks like its been pressed then its before the fuser but if its loose than its after. And thats how we can determine where it begins
Feb 12, 2009 | HP LaserJet 4350 Printer
Drawer problem
DRAWER OUT OF ORDER Copystar
You have to reset the drawer by; 10871087 and run SIM 906
You should be able to just key in the Code you wish, then hit the print key to activate.
Then use the touch screen to reset then print key again.
Jan 24, 2009 | Office Equipment & Supplies
White lines through anything I print
Try to clean the catridges and alligned the print head from the front panel menu of the printer.
Regards,  raj_p5983
Jan 20, 2009 | Epson Office Equipment & Supplies
Dell 1700 often jams in one spot
Just in case you don't know where the rollers are in the paper cassette...remove the paper cassette drawer and he rollers are at the top of the entrance to the drawer. There are two rollers, grasp one between your fingers and gentle pull the roller down to see the mechanism better. Rotate both rollers and you may find a build up of dirt/grime on either or both. Simple clean them with an appropriate wet cleaner & lint free cloth.
Mar 04, 2007 | Dell 1700n Laser Printer
Lexmark T642 Laser Printer Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
