My start menu shifted up iwant to bring it down
    Problem Solver:
  • 8 Answers
1. Right-click on your start menu and un-check "Lock the Taskbar". 2. While holding down the left mouse button, drag the taskbar to the bottom portion of the window (or where ever you want it.) 3. Once it is in place, Right-click on your start menu and check "Lock the Taskbar".
Hope this helps :)
Posted on Oct 05, 2010
Why can't I turn off safe mode?
If W10, Go to the Shutdown menu, and hold down Shift as you select Restart.
Select Troubleshoot > Advanced options > Startup Settings > Restart.
The computer will reboot. But instead of loading Windows, it will bring up a Startup Settings screen with all sorts of options. Press Enter "to return to your operating system."
Feb 04, 2018 | Computers & Internet
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Cheat codes
50,000 simoleans = motherlode
makes your sims larger or smaller = StretchSkeleton
Open the cheat menu by pressing Ctrl + Shift + C, then entering the following:
boolProp testingCheatsEnabled true
While in Create-a-Sim, press Shift + N before creating your first sim to enable skintones, clothes, and hairstles that would normally be used only by NPCs. Press Shift + M to disable it.
While in Live mode, Shift + Click on a sim to bring up the debug menu.
Jul 20, 2013 | Video Game Consoles & Games
How can i unlock my keyboard
Recognize that you have a locked keyboard.
If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
Use your mouse to move the pointer over the "Start" button.
Use the left-click button to bring up the "Start" pop-up menu.
Position the pointer over "Settings" and use the left-click button to select. T
hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
Select "Accessibility Options" to bring up another menu, then select "Keyboard."
You'll see three options that have check boxes.
Make sure each check box does not have a check mark in it.
The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
Turn off the computer.
Disconnect the power supply.
Remove and then reconnect the keyboard cable, then reconnect the power supply.
Turn the computer on.
This will reboot the computer, allowing it to recognize the keyboard.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
How do you put it in degree mode?
Press SHIFT [MENU] to bring up the setup screen. Move down to the "Angle" line and set the desired mode.
Jul 15, 2012 | Casio FX-9750GPlus Calculator
Iwant to know if lexmark x422 is alreary installed in my pc?
click on the start button at the start menu choose all programs then you can see if your lexmark appear on the program menu it means it is already programmed
Jul 12, 2011 | Cameras
Start menu and task bar is not responding for a mean while after i turn on my computer.
Please follow the given steps to relaunch the Start Menu and Taskbar:
1. Press Ctrl + Alt + Del or Ctrl + Shift + Esc to bring the Task Manager.
2. Go to Processes TAB
3. Find explorer.exe and select it
4. Click End Process (Button at Bottom Right Corner)
5. Click File Menu and Select New Task (File-->New Task(Run))
6. type in explorer and press ok
May 18, 2011 | Microsoft Windows XP Professional
SHIFTING
bring truck to auto parts store hook up OBD II computer diagnostic tool to plug under dash look for code and go from there it may be a shift solenoid or speed sensor.
Jul 01, 2009 | 1999 Dodge Ram
Graphing
Instruction book for this calculator is shocking for sure. It would take too long to explain fully, here is an example of plotting a simple Y= graph.
In main menu, when you first turn it on, press 1
This is normal calculator mode.
Press [shift] [menu] to get the set up parameters.
Scroll curser down one to Func Type, and select Y= if this is not already set, by pressing F1
Continue scrolling down to set Coord, Grid, Axes and Label functions. Turn these on or off as desired. Turn them all off for this example. F1 and F2 select On or Off here.
Press [exit]
Press [shift] F3 to access the V-window parameters. Here you set the size of the axis in the graph
Enter 0 for Xmin, 360 for Xmax, 0.1 for scale
Enter -1 for Ymin, 1 for Ymax, and 0.1 for scale
Press [exit]
Press [shift] F4 to enter graph plot mode (Sketch mode)
Press F1 then [EXE] to clear any previous graphs
Press F5 then F1 to select Y= type graph
Display should show Graph Y=
press [sin] [ X,0,T] (this key just under red alpha key) then [EXE]
Calculator should draw a sine wave, showing 1 complete wave
Try setting the parameters in Set up, Axes On, Label On etc to see the effect.
Hope this helps a little. Page 123 in book deals with graphing.
Mar 28, 2009 | Casio FX-9750GPlus Calculator
AR:235 SHIFTING MENU LANGUAGE
just follow the steps;
1, press "#", "interupt", "clear", "interupt" keys
2, press 26 press start.
3, press 22 press start
4, use up and down arrow key to select which you want
Dec 06, 2008 | Sharp AR-235 Copier
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
