Question about Panasonic PanaFax UF-8000 Laser Fax
Paper stucking sir, 2-3 times paper comming smoothly 3-4 times after strcking near fuser unit reason please
  • 148 Answers
Most times when this machine starts jamming at the fuser, it is time to replace the fuser,
Posted on May 28, 2008
Paper stuck in fuser unit
1) Grab the front cover grip and
open the front cover
2) Pull the handle of the imaging
cartridge toward you, and then
pull out the imaging cartridge.
Note
Do not expose the imaging
cartridge to light for a long period
of time, otherwise decreased
image quality may result.
3) Pull out the jammed media along
the feeding direction.
Note
If media is jammed in the fusing unit,
pull the media downward to remove
it.
CAUTION:
The fusing unit is extremely hot.
Touching any part near the fusing
unit may result in burns.
Do not touch the image transfer
roller inside the printer, otherwise
decreased image quality may
result.
4) Align the imaging cartridge with
the guides in the printer, and
then insert the cartridge.
Note
Do not insert the imaging
cartridge at an angle or with
extreme force, otherwise the
printer may be damaged.
5) Press on the front cover grip and
close the front cover.
Nov 21, 2013 | Konica Minolta PagePro 1300W Printer
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Ghost printing
Hi for ghost printing basically it is
1)fuser roller surface wear n tear
2)check any fragment of paper stuck at the fuser unit.
3)fuser unit is located near the printing output.
Sep 05, 2009 | Canon imageCLASS D761 Copier
Paper getting stuck in the rear of Brother 2820 fax machine...
Hi, There are many reasons for jams in the exit of machines and I will list the most common for you damp paper will curl as soon as it hits the fuser rollers... the fix - change paper the fuser rollers are worn (teflon coating is no longer able to deflect toner) and jams are occurring.... the fix - replace the fuser unit
Jun 09, 2009 | Brother IntelliFax-2820 Laser Fax
Toshiba 2060 jams (accordion/fans the paper) at the fuser unit. Torn Paper now stuck next to the roller/drum and now jams every time. How do I remove the torn bits of paper to keep it from jamming?
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Jan 11, 2009 | Toshiba 2060 Copier
Paper a misfeed
not sure if you are talking about two papers jammed in different locations or at different times?
first thing would be to clean the tires that pick up the paper, if too smooth then replace. sounds like a timing issue.paper getting stuck halfway in the fuser c(if no other paper jammed) can be Seperation is off causing the paper to rise onto the drum creating a time lapse, paper tansport belt (in the machine after the drum) is not turning ok, or as simple as wrong size paper Letter in machine but says Legal 8 1/2 x 14
Aug 26, 2008 | Ricoh Aficio 1018D Copier
Paper struck
Fusing rollers are not turning, Grease the bushings / bearings.
Perform Shipment Set.
May 27, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Aug 23, 2007 | Lexmark Optra T610 Laser Printer
Panasonic PanaFax UF-8000 Laser Fax Logo
63 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
