Question about General Electric A835 Digital Camera
Get rid of write protect - General Electric A835 Digital Camera
    Brigadier General:
  • 3,006 Answers
Your camera uses SD and SDHC memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty. Just check the manufacturer's website for support details.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my free answer has been of use and has given you options to fix your problem. Please let me know by taking a brief moment to rate my reply. If your problem has not been fixed, then please add a comment instead and I will suggest another solution for you.
Posted on Oct 06, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • General Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Oct 05, 2010
Get rid of k9 web protection on windows 7
You must uninstall not delete it!
Feb 18, 2014 | Computers & Internet
Tip
Display says Protect , and the unit does not start.
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
on May 27, 2009 | Sony STR-DE597 Receiver
How to get rid of protected card
Since you didn't specify the make and model of your camera I'm assuming it uses SD/SDHC cards.
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 21, 2013 | Cameras
How can i get rid of driver starforce as it is comming up blocked frm my pc vista
Star force is a protection system used mainly in protecting games and other software against illegal copying. I'm not sure exactly what you mean. If you are asking to help get rid of software protection, I'm afraid I cannot help. If however, you have the star force software on your computer (don't know why you would), the following link may help you
http://www.star-force.com/support/drivers/
Jul 02, 2011 | Computers & Internet
How do i get rid of my write protection on on the sd card
Wecome to Fixya. Memory card has a slide switch on the side or along the edges, you just have to slide it to get rid of the write protection on your memory card. Just remember that if the position nearest on the contacts is already removed the write protection on the SD card.
Thank you for using Fixya,
seancarlisle
Apr 30, 2011 | Cameras
Finepix Z20fd Digital Camera: How to get rid of Protected card...
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2010 | Fuji Finepix Z20fd Digital Camera
Stuck in protect mode
May 04, 2009 | Sony STR-D1015
How do i get rid of K9 Protecton ???
Go to add/remove program and remove the program K9 protection.
Apr 30, 2009 | Microsoft Windows 98
Protect screen on my sharp cd-ba150
that is your movement protection. In your manual it says how to get rid of it. mostelikely you have to push power and open button at same time
Jul 08, 2008 | Sharp CD-C662 Shelf System
General Electric A835 Digital Camera Logo
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
