Question about Frigidaire Freezer Refrigeration White Small Compact Chest Freezer Model FFC0723DW
I moved my fridge about 6 feet across the room and now it is leaking water and it isnt getting very cold can you help me its only a year old
    Problem Solver:
  • 5 Answers
Due to leakage in line from somewhere in you fridge
Posted on Oct 05, 2010
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
My freezer isnt as cold as it should be, top part of fridge isnt as cold and ice maker isnt freezing water
find the air vent and see if there is anything in front of them to prevent the air from recirculating. ice could be in the vents to,
Apr 13, 2010 | Freezers
I have a Whirlpook refrigerator, about 6 - 8 years
Try a quick fix by useing a blow dryer to thaw around the water tube and ice maker. Also for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 13, 2010 | Freezers
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
Fridge and Freezer running, but not getting cold.
make sure your fans are working. one is in freezer section,the other at back by your compressor.
Jan 06, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
143 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
