Question about GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator
We replaced the gasket today around the bottom drawer freezer on GE Monogram. The problem was that it was split and we thought that was reason it was not sealing. However, it still does not appear to seal on right-hand side - not enough pull from magnet? All baskets & drawers were removed, cleaned & replaced properly and seal near door fridge hinge side of freezer not sealing.
  • evan andersen Feb 06, 2013
    Did you ever find a resolution to this problem? We have the same problem, the gasket has been replaced but it still doesn't seal at the top. Our freezer is full of snow.
  • GE Master
  • 1,606 Answers
Use a hairdryer to soften the gasket until it pulls itself to the metal frame all around the gasket .
Posted on Oct 06, 2010
  • Mike Smith
    Mike Smith Oct 06, 2010
    After heating the gasket until it seals , wait for the rubber to cool before opening the door . Also , putting a light coat of mineral oil on the hinge side of the gasket , will help it slide easier ( instead of pulling ) while opening and closing the door .
    Problem Solver:
  • 5 Answers
You should one agin need to change the gas kit by purchsing it from the authorised shop of manufacture of brand of the fridge.
Posted on Oct 05, 2010
Why is the refrigerated side freezing food?
Your freezer door seal may be the problem forcing the freezer side to work too long, thus affecting fridge side.
May 31, 2015 | GE Monogram ZISS480DRSS Stainless Steel
Moisture building up on left side of freezer drawer and dripping onto floor
HI FRED.check if its screwed on ;pushed on;or bonded.if bonded complete door replacement.hope it helps Ali
Jun 25, 2012 | GE Monogram ZICS360NR Bottom Freezer...
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Kitchenaid bottom drawer freezer is making frost or ice flakes inside. Why?
If frost is front towards door then the seal is not sealing well . Use a hair dryer on portion which is not touching cabinet . Also check for split somewhere on gasket & if found , replace gasket . If frost on the rear wall of freezer , then a defrost problem could be starting in which the fridge section would be warming up . However , bottom freezers are known for their gaskets not to seat properly .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
GE Monogram ZICP360SRSS - Ice cubes spill out of icemaker bucket
sorry, but not unless you want to get into spending some serious time.
Jul 29, 2008 | GE Refrigerators
GE Monogram Won't Drain completely
the drain was clogged. A handyman used a snake to clean it out.
Apr 04, 2008 | GE 24 in. Monogram ZBD6880KSS Stainless...
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator Logo
229 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
