Question about Alpine CDA-9884 Car CD/ MP3 Player
I used the wiring connecter so as not to slice the wires but there is no volume coming from the cd player or ipod. there is sound coming from the radio portion of the unit. the ipod and cd changer play and you can change the tracks but no volume
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
Are you using an amplifier? it sounds like you are using the blue wire (antenna remote) instead of the blue/white stripe wire (amp remote) to turn it on.
Posted on Oct 05, 2010
I put in a cd player everythings connected but there is no sound coming out of the speakers
check your wiring, make sure its not grounded behind the dash somewhere
Sep 18, 2010 | 1993 Lexus Es 300
I want to hard wire (not using any kind of wireless gadget) my ipod in to my car to the Kenwood KDC 334 CD player which is installed. I have pulled the Kenwood unit out and there is no obvious connection,...
The KDC 334 doesn't have any audio input, so there's nowhere to hardwire an iPod or other mp3 player into the unit.
I'm sorry, but the only way to get iPod sound to come through this head unit is with a wireless gadget like the iTip FM adaptor.
Feb 18, 2010 | Kenwood KDC-334SA CD Player
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
Tuner works, however I have no sound for the cd or auxilliary players (MP3/IPOD) Cd's are playing, just no volume
If this was recently installed - chances are good that your installer used the wrong amplifier turn on wire.
You have the amplifier remote and power antenna wires reversed.... so when the am/fm radio turns off, it drops the signal on the antenna - and it retracts.
When you switch to a different source - your amplifier loses its turn-on lead power, and shuts off.
Reverse the blue & Blue/White wires, and you will be fixed. :D
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 12, 2009 | Sony CDX-GT710 CD Player
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Sound Issues
The player has a built in safety device which only allows it to turn up so high. It help to avoid burning out your equip ment. Best way is to put sound on one device 3/4 ways up and then use the other device for adjusting the volume from there.
For sound in one channel; either there is a wire unplugged or not getting a good contact, or the player is set for mono instead of stereo
Jan 22, 2008 | Alpine CDA-9856 CD Player
Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
Jan 21, 2008 | Kenwood KVT-617DVD Car DVD Player
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Alpine CDA-9884 Car CD/ MP3 Player Logo
101 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
