Question about LG Televison & Video
In trying to set up the wireless internet for my LG 50Pk750, when I go to the setup screen on the TV it locates my home network just fine, but when I try to enter the security code for my network, I cannot get the remote control to input numbers onto the TV screen, only characters. Is there a shift or change button etc on the remote that will let you switch between numbers and characters?
  • Anonymous Mar 29, 2014
    Can not connect to wifi. When we go to network setup it seems to be set to wired and we cannot change it to wireless
Try pressing the volume button to switch to alphanumeric key pad.
Posted on Dec 10, 2010
48" HISENSE SMART TV 2014 /I HAVE NO WIRELESS INTERNET CONNECTION ANYMORE
Check out your manual and look for the section regarding connecting to your home network. The tv set must detect the network for it to properly set up the connection after you give it the name and password to your account.. Check for the network working properly with your laptop or other device(s). If those units connect then the problem has to be with the wireless circuits of your tv.
Can also try resetting the set to factory condition and starting anew with the setup procedure. Also unplug the set while it is on - then while unplugged press in the "on" button on set for about thirty seconds. Then replug set and try again.
Mar 06, 2016 | Hisense Televison & Video
How to connect tv to internet for netflix
First, I am assuming that you have the internet connected at your house and I am assuming that you have a wireless access point or a router with Ethernet connections on it. If you do not have these, then you cannot connect to the internet. On most smart TV's they have a "settings" or similarly named menu item, where you can connect to your home wireless system. Select this and then scroll down the menu until you fine something that says internet or wireless or even quick setup. From there you just select wireless, type in your access password and it should work. All this will be explained in the owners manual for your smart TV.
Feb 25, 2016 | Magnavox Televison & Video
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Need to connect my tv to the internet
Wifi dongle will available for TVs. If you had USB port on TV,connect that dongle on that and access internet.
Nov 10, 2013 | Sharp LC46SB54U 46 in. LCD TV
My KC550 lg does nt run internet .I received settings also but it give s communication error.why?
First what is a KC550 lg , laptop , deskop , mobile phone.
Im assuming phone have you synced with the wireless router ?
Connecting your LG phone to wireless Internet is easy to accomplish with phones that can receive Wi-Fi signals.
You may decide to use the Wi-Fi capabilities in the event that you do not receive the best signal from your wireless provider at your home or office.
If this is the case, then hooking up to a Wi-Fi network near you could provide you with a faster connection to the Internet and a more reliable signal to send e-mails, texts and pictures.
Press the "Applications" tab on the home screen of your phone.
Scroll down the list of applications until you reach the "Settings" option.
Press "Settings" to bring up the menu.
Locate and click the "Wireless & Network" or "Connections" option within the "Settings" menu.
Select the "Wi-Fi Setting" or "Wireless Manager" option, then select the network that you want to connect to and click "OK."
All of the available wireless networks within your range will appear.
Enter the wireless network password (usually located bottom of router) if you are connecting to a secure network.
Press the "Done" button followed by the "Connect" button.
Jul 26, 2013 | Computers & Internet
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
Brand new Dell netbook won't connect to internet (at home). Connects fine at work. Wireless strength is good at home but no internet connection. Husband's notebook connects just fine so it appears to be an...
No, it's probably because you have setup a wireless home network with security in place.
Go through the settings on your husband's notebook settings for your home network and set your Dell up the same way. You will need to know the SSID for the wireless network, security type and key to set it up.
Oct 28, 2009 | Dell Computers & Internet
Dlink DI524 wireless problem: cannot access the router
If the Router is new proceed to Step 1. If the Router is used power on and press and hold the Reset button for about 10 seconds. It is located next to where the power cord is plugged in. Use either a pen or paper clip to push reset button.
Step 1. Connect one end of an Ethernet cable to the Ethernet port located on the Cable / DSL modem and the other end to the WAN port on your D-Link DI524 wireless Router. The WAN LED light will illuminate to indicate proper connection.
Step 2. Connect one end of an Ethernet cable to LAN Port 1 on the back panel of the DI-524 and the other end to the network adapter in the computer you are using to
configure the DI-524. The LED light for LAN Port 1 illuminates to indicate proper
connection.
Step 3. Once all pieces ar connected. Open your Web browser and type http://192.168.0.1 into the URL address box then press ENTER. Once the log-on pop-up screen appears type admin for the user-name and leave the password blank then click ok.
Step 4. Once you have logged in, the Home screen will appear and you should see a box called RUN WIZARD in the middle of the screen. Click that box and follow the steps.
Setup Step 1 - Click Next
Setup Step 2 - Create Password and click Next
Setup Step 3 - Choose Time Zone and click Next
Setup Step 4 - Setup wizard will try to auto-detect your Internet connection type.
Setup Step 5 - Select your Internet Connection. You will be prompted to select the type of Internet connection for your router. More than likely it will be Dynamic IP Address. Click Next.
Setup Step 6 - Click the “Clone MAC Address” button to automatically copy the MAC address of the network adapter in your computer. You can also manually type in the MAC address. Click Next.
Setup Step 7 - The default wireless settings for your 802.11g wireless network are: SSID = default Channel = 6. You can change the SSID name to whatever you like. This will be the name of your wireless network. Click Next.
Step 8 - If you wish to use encryption for your 802.11g network, the DI-524 is capable of two levels of wireless encryption - 64-bit and 128-bit. By default the encryption is disabled. You can change the encryption settings for more secure wireless communication. If you choose to use encryption, you will need to write down the encryption key so that you can connect your laptop or pc via wireless connection. Click Next
Setup Step 9 - Your is complete. Click Restart to save and reboot your router.
Setup Step 10 - Click Close to complete your setup.
Setup Step 11 - You will be returned to the Home tab. Close this window and wait for the Router to finish rebooting. Then relaunch your Web browser (i.e., Internet Explorer or Netscape Navigator), to link to your favorite Web site to test your Internet connection.
Here is the link to download all the necessary info to configure your router - http://www.dlink.com/products/?pid=DI-524&tab=1
Jun 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Televison & Video Logo
300 people viewed this question
Computer Repairing
Computer Repairing
